Yesterday's Tractor Co. The Right Parts, Right Away
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: jd 2950 4x4 steering issue
[Return to Forum]
jackedup
10-29-2012 13:28:42
12.54.128.7
I have at 2950 mfwd that the steering will just quit turning.wiggle the wheel left to right and the steering comes back.this is a low hour machine under 1000 hrs.The loader also will not operate when this happens.Any ideas what needs fixed to correct this?
[Reply]   [No Email]
Tx Jim
10-30-2012 04:18:07
67.142.163.24
 Re: jd 2950 4x4 steering issue in reply to JohnDeereM50, 10-29-2012 13:28:42
What type valve controls the loader(scv or ind). If ind valve disconnect valve return hose and start engine,if oil flows out of hose with controls in neutral then valve has reverted to open-center. The main hyd pump must be loosing stand-by pressure for both steering and loader hyd's to quit operating. I'd suggest getting a 3000 psi gauge and monitor stand-by pressure. Do pto or hyd hi-lo operation affect hyd functions??
How long since hyd filter was changed and sump screen checked/cleaned??
[Reply]  [No Email]
buickanddeere
10-30-2012 09:40:44
184.151.61.166
 Re: jd 2950 4x4 steering issue in reply to Tx Jim, 10-30-2012 04:18:07
Make of loader control valve(s)? Is there a relief valve inside
the control valves ? Is the steering problem new or always
existed? Have to wonder if the tractor was miserable to drive ,
thus the low hours?
Dubuques and Mannheims need to return high flow oil loads
into a ported filter cover.
[Reply]  [No Email]
jackedup
10-30-2012 11:19:26
12.54.128.7
 Re: jd 2950 4x4 steering issue in reply to buickanddeere, 10-30-2012 09:40:44
The tractor was just bought at a dealership it was traded in.Just bought the machine last week and only used it a couple hours to rake a field of hay and then move the bales.The loader is a bush hog 2840 model. I am going to check the filters and scavage screen this weekend and go over the entire machine.The tractor looks and and is tight as new.I hope this is something easy to find/fix.
[Reply]  [No Email]
buickanddeere
10-30-2012 15:05:30
184.151.61.183
 Re: jd 2950 4x4 steering issue in reply to jackedup, 10-30-2012 11:19:26
Could be the problem right there with the valve the loader maybe using.
You still haven't told us if the loader have it's own valves or uses the SCV valves. Or if the loader is supplied from the scv or plumbed direct.
[Reply]  [No Email]
jackedup
10-31-2012 04:30:15
12.54.128.7
 Re: jd 2950 4x4 steering issue in reply to buickanddeere, 10-30-2012 15:05:30
I will have to inspect the plumbing and get back with info on this as i am out of town now and won't be back until tomorrow .So I will check it out and get back.If I do recall there is a big valve on the loader with the lines being tapped in to the plumbing on the right side of the machine.thanks for everyones help so far.I will hopefully be able figure something out with all the great info I have gotten.
[Reply]  [No Email]
buickanddeere
10-31-2012 05:18:54
184.151.61.183
 Re: jd 2950 4x4 steering issue in reply to jackedup, 10-31-2012 04:30:15
Check and see if the oil return line from the control valves back into the tractor. If the line is flowing oil when the loader hydraulic controls at rest. There would be the problem.
Return oil must flow to a ported filter cover. Just dumping the oil back into the transmission case starves the front pump.
[Reply]  [No Email]
Craig C
10-29-2012 17:02:11
98.93.56.151
 Re: jd 2950 4x4 steering issue in reply to jackedup, 10-29-2012 13:28:42
Are those correct hrs, or has it only been used less than 40hrs per year for the past 25 years or so? Most utility tractors get more use than that especially with a loader attached.
[Reply]  [No Email]
jackedup
10-29-2012 18:01:59
12.54.128.7
 Re: jd 2950 4x4 steering issue in reply to Craig C, 10-29-2012 17:02:11
The tractor was used on a small 100 acre farm and was used only to move round bales.Talked to friend of the original owner that bought it new and said yes they were correct hours.we were told he had the tractor for only that job and took great care of it.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
