Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: 4040 seat accumulator problem
wp77
10-27-2012 20:38:31
There is no valve on this accumulator to check the pressure. It came with a nitrogen charge in it already. I will try try your test to see how much fluid comes out the return tomorrow. Thanks for your suggestions.
DEEREMEYER1
11-02-2012 09:19:19
 Re: 4040 seat accumulator problem in reply to wp77, 10-27-2012 20:38:31
No testing port? There has to be a valve, or they wouldn't be able to charge them. Is there a hex cap on the end opposite the fitting that screws into the valve? If so, unscrew the cap and there should be a shrader valve underneath. I've never heard of accumulators coming pre-charged, but I suppose it's possible.
wp77
11-03-2012 06:59:50
 Re: 4040 seat accumulator problem in reply to DEEREMEYER1, 11-02-2012 09:19:19
Yes, it did come pre-charged. You can go to abilene machine"s website and see for yourself. I think there is a hex plug on one end. I was just afraid to unscrew it because I thought maybe it was holding pressure. I know this accumulator has at least some charge in it, because it works much better than the old one it replaced. Something"s just not working correctly. That"s why I wanted to know if something else could be causing the problem.
Tim S
11-03-2012 16:27:12
 Re: 4040 seat accumulator problem in reply to wp77, 11-03-2012 06:59:50
The plug exsposes the valve, it holds 90 psi it could be low, and if you check it it will make it low,,,Darn it,,if it was here I would re-fill it and see what happens...
wp77
10-29-2012 13:23:23
Do you know exactly where that return line plugs in? Would it be the third line that goes tees into the attenuator? I can"t trace it under the cab. I see it on the left hand side, but can"t see where it goes from there. The 4040 cab sits very low on the chassis unlike the larger 40 series.
