TractorLinks.com
Show Parts for Model:
48 B and plow
wijim
10-27-2012 14:26:55
Ok so we picked up a f125 2 bottom today put on the tractor and it won't pick it up without helping a little. When it is up it stays there.Is there a bypass that can be adjusted on the powertrol? Tha engine does not labor when picking it up.Thanks, Jim
Wilamayb
10-27-2012 19:45:29
 Re: 48 B and plow in reply to wijim, 10-27-2012 14:26:55
I would perform a pressure check on your scv. If it is up to pressure I would leave it be. The B was not suggested by Deere to be used with the 800 hitch, and for good reason. Even if you get the B to pick it up you won't be able to keep the fronted on the ground. A 44 plow will suit the B. if you insist on a mounted plow get a 50 or an A.
wijim
10-27-2012 18:55:23
I shimmed it more then I should and it still sounds like it is bypassing.Is ther anything else to look for? The plow is up in the air to see if it settles overnight.
Lon in NE
10-27-2012 16:54:23
Can we say aluminum can??? It's easy to cut and THIN! There will be no wear, it just takes up space.
Lon
wijim
10-27-2012 17:14:30
 Re: 48 B and plow in reply to Lon in NE, 10-27-2012 16:54:23
I just measured the thickness of the shims that were in there subtracted the thickness of a washer and added enough thin shims to bring it back to original and added 2 more shims. we'll see if that works here in a minute.
gtx1967jewison
10-27-2012 15:28:31
You need the Owners manual. Its in there. Also, a larger diameter cylinder is the best approach, as it gets alot heavier when stuck in the ground. Make sure you have 30 wt oil in the powertrol also.
wijim
10-27-2012 15:33:44
 Re: 48 B and plow in reply to gtx1967jewison, 10-27-2012 15:28:31
Its a mounted plow and we run Hyguard in everything. Thanks
wijim
10-27-2012 15:17:59
I have parts and service manual and neither have adjustment info.
wijim
10-27-2012 15:27:27
 Re: 48 B and plow in reply to wijim, 10-27-2012 15:17:59
I think I found the proper adjusting screww. But they talk about removing/adding washers to adjust the presure that I don't find in the books i have any help would sure be nice. Thanks, Jim
wijim
10-27-2012 16:36:23
 Re: 48 B and plow in reply to wijim, 10-27-2012 15:27:27
I did some searching and found where the presure relief valve and spring are now to find some thin washers.
