Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: worth fixing
husker44a
10-27-2012 12:27:04
I agree with Bushog, I would re check your clutch. You just overlooked something simple. Hang in there you will get it going. What did you replace in the clutch. Just the disks? Or everything? Good luck.
alvan
10-27-2012 13:28:09
 Re: worth fixing in reply to husker44a, 10-27-2012 12:27:04
hsd to replace everything when i got it the clutch cover was on and when i took it off to check the clutch it was empty.So i had to buy two disk a driver and a ajustment plate i have check and reasembled 2 or 3 times and no change to much end play even tighting up the flywheel confused.I have a 45 A hand start that has end play and clutch works fine.
Ray Durham
10-27-2012 17:23:00
 Re: worth fixing in reply to alvan, 10-27-2012 13:28:09
Alvan, I also have a 1945 hand start model A. Contact me off list at my email address which is durham49@cox.net
Thanks, Ray
BushogPapa
10-27-2012 17:07:38
Did you put one Friction Plate in Before the Clutch-Driver went on..??
alvan
10-27-2012 18:13:07
 Re: worth fixing in reply to BushogPapa, 10-27-2012 17:07:38
Yes instaled a disk then driver then a nother disk then adjustment plate cant get the snap out of the clutch.thanks for the reply.
gtx1967jewison
10-28-2012 07:28:34
 Re: worth fixing in reply to alvan, 10-27-2012 18:13:07
Often times a new aftermarket driver doesn't go on far enough so you need to put 2 disks behind it. Use a worn one & a new one or 2 worn ones etc. Also, if you remove the whole pulley you can look at the T-bolts & dogs to see if worn excessively. There's a bearing & a bushing in therethat need clean grease also.
alvan
10-27-2012 18:16:38
i have to tighten nuts up to far to get any clutch at all and then very little clutch. disk are new driver new adjustment plate used but has new springs.
rick deere
10-28-2012 15:23:32
 Re: worth fixing in reply to alvan, 10-27-2012 18:16:38
lever must be forward when you start adjusting nuts
