Yesterday's Tractor Co. Compare our Prices For Parts
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Why not to drive a John Deere without the brake drums on
[Return to Forum]
goatboy
10-27-2012 12:15:13
74.140.87.127
I have never posted on the JD side before but I recently had the wild hair to own a 2 cyl (I'm a Farmall guy, but love all tractors). So I bought a 70, it runs ok but needed brakes. I pulled the drums off. While waiting for parts I needed to move the tractor so I went to move it, I made it about 30 feet when all at once the entire right side brake assembly broke off and fell to the ground. That is not the worst part, without the brake drums on the brake shaft slid inwards and hit ring gear breaking it. So the brake shaft slid towards the ring gear cocking the brake shaft braking off the brake assembly and one of the planetarys on the ring gear. Just another lesson learned the hard way. My question is would it be easier to unbolt the entire rear end with the axles in place or should I remove the axles and bull gears from the rear end housing. A friend told me that's what I get for switching colors
[Reply]   [No Email]
Kurt_JDB
11-10-2012 06:17:15
74.167.224.109
 Re: Why not to drive a John Deere without the brake drums on in reply to goatboy, 10-27-2012 12:15:13
Goatboy,
Recognize that you may have a potentially very unstable tractor the way you are supporting the front. I can't quite tell from the pictures, but if you have a rollomatic front end, the only thing keeping your tractor from pitching over on it's left side is the fact that it is balanced on the blocks under the main case. It looks like you only have a jack on the right side. The Rollomatic allows the front wheels to move up and down in opposite directions, so they do not provide any lateral stability to prevent a roll over.
There was a fellow on here a few years ago who posted a picture of his tractor that fell over after supporting it like you have done. He was very lucky not to be injured. Be safe.
Kurt
[Reply]  [No Email]
goatboy
10-28-2012 16:29:21
74.140.87.127
Splitting it wasn't bad at all. Getting the dif. out was a little trickey. Can I still get gaskets from a john Deere dealer?
[Reply]  [No Email]
FactoryFarmer
10-30-2012 20:12:18
184.20.120.249
 Re: Why not to drive a John Deere without the brake drums on in reply to goatboy, 10-28-2012 16:29:21
Yes you still can! :D
[Reply]  [No Email]
MoMark
10-28-2012 09:35:01
69.55.153.212
Goatboy,
Don't let that friend's comment sour you on these old 2-cylinders. He was probably joking but rest assured, this is uncommon & these things are pretty bulletproof. I agree that you would be better off to roll the entire axle housing away unless you need to replace the axle seals & do other work in there too.
[Reply]  [No Email]
Mike M
10-27-2012 18:24:19
70.194.1.48
You have to split it apart at the main case to rear axle housing to get the diff. Out. Pulling the axles and bull gears will not let you get it out.
[Reply]  [No Email]
gtx1967jewison
10-27-2012 15:37:02
174.253.132.249
The rivets should have been a clue. They are meant to be removed /serviced as an assembly. Easier that way anyhow, on a bench. Also, repair manuals are your FRIEND, even on "simple old relics".
The best way is to build good stands to hold the maincase & spin the bolts out & just wheel the hole a$$ end away. Good luck! :-)
It really sucks when things break on ya that's for sure
[Reply]  [No Email]
Scott in SC
10-27-2012 16:14:26
97.107.97.14
 Re: Why not to drive a John Deere without the brake drums on in reply to gtx1967jewison, 10-27-2012 15:37:02
gtx,
The drums are not riveted to the shaft on a 70, they have a nut on the shaft and are removable. Clampdaddy said his A had drums riveted to the shaft, as I’m sure it did. The 70 and other models are different.
Scott
[Reply]  [No Email]
CLW
10-27-2012 12:58:09
108.206.122.51
 Re: Why not to drive a John Deere without the brake drums on in reply to ShadetreeRet, 10-27-2012 12:15:13
[Reply]  [No Email]
clampdaddy
10-27-2012 12:29:36
50.8.151.226
Ouch!!! I always wondered why the drums were riveted to the brake shaft on my "A" instead of using an easily remiveable bolt on drum like cars use.......now I know.
This post was edited by clampdaddy at 12:30:29 10/27/12.
[Reply]  [No Email]
goatboy
10-27-2012 12:18:44
74.140.87.127
a couple more photos of the destruction
[Reply]  [No Email]
scotc
10-30-2012 20:07:45
75.234.227.50
 Re: Why not to drive a John Deere without the brake drums on in reply to goatboy, 10-27-2012 12:18:44
It needed a good cleaning out anyhow.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
