Yesterday's Tractor Co. Fast, Friendly Parts Service
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Re: 4040 seat accumulator problem
[Show Entire Topic]  [Return to Forum]
Tx Jim
10-27-2012 03:58:33
67.142.163.23
IIRC the accumulator gives the seat a soft(cushioned)ride along with a dampening valve and a pressure control valve that limits the pressure to 300 psi. Does your accumulator have a valve stem similar to JD? If so I'd put an air gauge on it and check nitrogen pressure. With engine off disconnect seat valve return hose on top of clutch housing. Crank engine and measure oil flow from hose. Discharge should not exceed 1 pint per min.
[Reply]   [No Email]
Tim S
10-27-2012 11:01:18
75.49.6.218
 Re: 4040 seat accumulator problem in reply to Tx Jim, 10-27-2012 03:58:33
Most accumulators come "un-charged" and the need filled with compressed nitrogen, I know the Deere ones are un-charged...
[Reply]  [No Email]
wp77
10-27-2012 20:38:31
64.203.118.82
 Re: 4040 seat accumulator problem in reply to Tim S, 10-27-2012 11:01:18
There is no valve on this accumulator to check the pressure. It came with a nitrogen charge in it already. I will try try your test to see how much fluid comes out the return tomorrow. Thanks for your suggestions.
[Reply]  [No Email]
DEEREMEYER1
11-02-2012 09:19:19
71.8.242.10
 Re: 4040 seat accumulator problem in reply to wp77, 10-27-2012 20:38:31
No testing port? There has to be a valve, or they wouldn't be able to charge them. Is there a hex cap on the end opposite the fitting that screws into the valve? If so, unscrew the cap and there should be a shrader valve underneath. I've never heard of accumulators coming pre-charged, but I suppose it's possible.
[Reply]  [No Email]
wp77
11-03-2012 06:59:50
64.203.118.82
 Re: 4040 seat accumulator problem in reply to DEEREMEYER1, 11-02-2012 09:19:19
Yes, it did come pre-charged. You can go to abilene machine"s website and see for yourself. I think there is a hex plug on one end. I was just afraid to unscrew it because I thought maybe it was holding pressure. I know this accumulator has at least some charge in it, because it works much better than the old one it replaced. Something"s just not working correctly. That"s why I wanted to know if something else could be causing the problem.
[Reply]  [No Email]
Tim S
11-03-2012 16:27:12
201.116.215.18
 Re: 4040 seat accumulator problem in reply to wp77, 11-03-2012 06:59:50
The plug exsposes the valve, it holds 90 psi it could be low, and if you check it it will make it low,,,Darn it,,if it was here I would re-fill it and see what happens...
[Reply]  [No Email]
wp77
10-29-2012 13:23:23
64.203.118.82
Do you know exactly where that return line plugs in? Would it be the third line that goes tees into the attenuator? I can"t trace it under the cab. I see it on the left hand side, but can"t see where it goes from there. The 4040 cab sits very low on the chassis unlike the larger 40 series.
[Reply]  [No Email]
[Show Entire Topic]     [Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
