Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
JD 50 PTO/First Reduction Cover Area Clunk?
Copper Lincoln
10-26-2012 17:36:28
JD 50 tractor (live PTO) and JD #5 Mower - I'm hearing a clunking in the clutch-side/first reduction cover area at my feet only at times when using the #5 mower and passing through a thicker clump of heavy grass and working the machine a little harder(clipping pasture weeds in the South with some Bermuda grass patches)or sometimes while climbing a steeper incline and mowing. Also don't know if it's related but when trying to get going on the road in 6th gear I hear a simular clunk at my feet when I first engage the clutch to take-off. I am wondering what kind of problem these could be, and how difficult it could be to repair, and where to even start looking? Thanks for any insights.
buickanddeere
10-27-2012 06:59:28
 Re: JD 50 PTO/First Reduction Cover Area Clunk? in reply to Copper Lincoln, 10-26-2012 17:36:28
It may not be the primary problem but the bearing in the reduction gear cover has probably failed and is wallowing out the housing.
GaryInKS
10-26-2012 19:41:20
The bushing on the PTO drive is probably bad.The one by the bevel gears.
BushogPapa
10-26-2012 18:57:41
As a precaution, it would be advisable to check the flywheel and Clutch-Driver for looseness or wear..
It seems that you are saying that you do not hear that sound at start-up or idle..??
Ron..
Copper Lincoln
10-26-2012 19:11:06
 Re: JD 50 PTO/First Reduction Cover Area Clunk? in reply to BushogPapa, 10-26-2012 18:57:41
That's correct it only makes the noise when the tractor/PTO starts to work harder.
BushogPapa
10-26-2012 19:25:51
 Re: JD 50 PTO/First Reduction Cover Area Clunk? in reply to Copper Lincoln, 10-26-2012 19:11:06
Just to be sure to probably eliminate the engine from this noise, have the engine idle and while running, pull one plug wire off and see if that noise appears..do this with each cylinder..
Does that sound go away and never appear when the PTO is not engaged..??
Ron..
Copper Lincoln
10-27-2012 06:09:04
 Re: JD 50 PTO/First Reduction Cover Area Clunk? in reply to BushogPapa, 10-26-2012 19:25:51
The noise seems to be PTO related and only happens when the PTO is engaged and the PTO equipment bogs down with a heavier load. I can mow a long way in peace and then hit a clump of really thick and heavy grass and then it clunks and clanks like a metal shucking noise pretty bad until I get back into the normal pasture grass. The only other time I ever hear a noise from this tractor is when I try to start out in 6th gear I get a few clunks till I get going BUT I'm not sure the two situations are related. The motor itself runs great so I'm thinking it has to be something from the clutch back? Maybe a bad bearing somewhere inside??
BushogPapa
10-27-2012 17:13:15
 Re: JD 50 PTO/First Reduction Cover Area Clunk? in reply to Copper Lincoln, 10-27-2012 06:09:04
Does it do this when on another PTO powered implement..?? Could it be that the Slip Clutch is chattering when under a Heavy Load..??
Ron..
