Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
JD 60
jwuertz
10-26-2012 15:41:45
Need advice for the best way to remove rusted, and burned exhaust manifold to head bolts without breaking them.
buickanddeere
10-28-2012 13:01:25
 Re: JD 60 in reply to jwuertz, 10-26-2012 15:41:45
Not a big deal or difficult to remove the head from a 60. The port gasket faces are likely eroded and needs milled down to a fresh square flat surface. Otherwise the manifolds will never seal. Won't do any harm to true the head gasket face with a slightly coarse stone. It's an opportunity to measure bore wear, look for cracks in the top of the bore,,valve stem/guide play and valve spring pressure.
jwuertz
10-28-2012 09:52:48
Will a propane ex. manifold work in place of a gas manifold?
Does anyone know? I see bolt holes are different on the manifolds
Tim S
10-28-2012 10:20:52
 Re: JD 60 in reply to jwuertz, 10-28-2012 09:52:48
Yes it will fit nicely, I have one on my 60C
jwuertz
10-28-2012 11:54:44
 Re: JD 60 in reply to Tim S, 10-28-2012 10:20:52
Thank you, are the bolt holes different?
BushogPapa
10-26-2012 19:33:04
Patients, patients, patients..you don't want to break them off flush with the Had..if you do, you will probably need to drill them out.. If you need to.. tease them until they are free in the Manifold..cut the bolt heads off and raise it as high as possible.. Cut the bolts, leaving as long a stub as you can, remove the manifold and Heat the stubs Red, tap lightly with a hammer, let cool and they will come right out..
Ron..
jwuertz
10-26-2012 19:48:16
 Re: JD 60 in reply to BushogPapa, 10-26-2012 19:33:04
Great advice here, Thank you all
jwuertz
10-26-2012 16:06:48
Heat the bolt near the bottom of the exhaust manifold?
Ben.So.Tex
10-26-2012 17:11:09
 Re: JD 60 in reply to jwuertz, 10-26-2012 16:06:48
Yes
jwuertz
10-26-2012 18:40:11
 Re: JD 60 in reply to Ben.So.Tex, 10-26-2012 17:11:09
Thankyou, I'll try it
Ben.So.Tex
10-26-2012 15:59:23
Heat them up and put a drop of oil on them let it cool, Reheat and out they come, worked for me many times,
Bob Harvey
10-26-2012 16:04:28
 Re: JD 60 in reply to Ben.So.Tex, 10-26-2012 15:59:23
Candle wax also works.
Copyright © 1997-2015 Yesterday's Tractor Co.
