| John Deere Tractors Discussion Forum |
Topic: 3020 cranks over real slowwwwwwwww
[Return to Forum]
| Author |
[Modern View]
| Little Red
10-26-2012 12:13:09
216.105.223.2
My tractor cranks very slow 12v neg ground gas. the battery is almost new cables are all clean and tight timming is dead nuts on . if I shut the hyd bypass off on the pump off it does crank almost twice as fast but thats a pain to do every time, could my pump be building to much pressure ?? Thanks for any suggestions on this Doug R |
| larryanderson
10-27-2012 12:59:48
184.21.172.50
Re: 3020 cranks over real slowwwwwwwww in reply to Little Red, 10-26-2012 12:13:09
| Didnt see that three letter word gas.I sometimes read too fast or cant see too good.Thats what happens to us older folks. |
| Tx Jim
10-27-2012 04:23:36
67.142.163.23
Re: 3020 cranks over real slowwwwwwwww in reply to larryanderson, 10-26-2012 12:13:09
| larryanderson
I would agree with you if LITTLE RED's 3020 was diesel instead of a gasoline. 12v starters for gasoline engines just don't give as much trouble as diesel starters. |
| larryanderson
10-27-2012 03:45:57
184.21.172.50
| If the battery is good and large enough cold cranking amps and cables are large enough and have the proper ends the starter is your next place.I just bought a diesel tractor that was having issues with starting.This fellow had pump redone,put on new lift pump,new JD batteries and cables,new alternator with same result and I asked him about starter which he then replaced even though it wasnt that old and it started fine.He probably spent well over $1000 by trying to do it himself when a place with proper testing equiptment should have found it .At least those items are new so it should be good to go.Add on ends are the weak link many times or cheaper replacement batteries. |
| Tx Jim
10-27-2012 03:38:30
67.142.163.23
Re: 3020 cranks over real slowwwwwwwww in reply to Clint Barnhart, 10-26-2012 12:13:09
| Quoting Removed, click Modern View to see
Doug
Besides checking stand-by pressure at scv one can also check it on frt pump. If de-stroking frt pump doubles cranking speed then there is an underlying hyd problem that I think a brand new starter won't correct. If the manual de-stroking screw is too inconvenient one could install a high $$$$ electric DS screw. |
| 4020_1966
10-26-2012 21:42:28
184.20.210.10
| Check it at the scv. Now let's back up step and find out for sure the problem. Did the slow cranking start with temp change or did it do this in warm weather? Destroking the pump is a bandaid option, not a fix for every slow cranking tractor. How old is the starter and have you had it checked recently? Old starters and poorly rebuilt ones are weak and don't have guts they should. If it's getting weak of course a destroker will help for a little while. You still will have a dieing starter. A small gas engine like that should crank fine on very cold days without a destroker if your starter, cable connections, cables, and starter solenoid are all in good shape. And yes when used in the correct situations a destroker is a great thing. One last thing, make sure the cables are actually good all the way thru. Old cables lose fibers and cannot carry current loads they used too.
This post was edited by 4020_1966 at 21:44:48 10/26/12. |
| Little Red
10-26-2012 13:40:27
216.105.223.2
| Jim I got the book on this tractor but don't remember off hand where you check the pressure I,m thinking under the dash panel |
| Tx Jim
10-26-2012 13:20:15
67.142.163.27
Re: 3020 cranks over real slowwwwwwwww in reply to Tim S, 10-26-2012 12:13:09
A 3000 psi gauge would be required to answer that question. |
| buickanddeere
10-26-2012 12:56:37
216.183.150.110
| Little Red
10-26-2012 13:16:04
216.105.223.2
Re: 3020 cranks over real slowwwwwwwww in reply to buickanddeere, 10-26-2012 12:56:37
| Manual destroker valve Me |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
