Topic: 1975 2630 john deere low engine oil pressures
[Return to Forum]
| Author |
[Modern View]
| Danny c
10-24-2012 20:55:48
166.147.120.160
I am new to the forum , but need some help with my new to me 2630 the tractor has a dealer rebuilt motor , about 1500hrs on it,runs and starts great but runs about 20 lb,s low on oil pressure, j have been told to check pump o rings cam ,crank, and main bearings , when the tractor warms up the oil pressure drops to35 at feld rpm , and at idle the oil light comes on ,have to keep fast idle just wornding if any one could give me any other thoughts or suggestions , this is a great tractor and I would like to fix this problem everything else works great,it is the optional Hyd pto with the high low shift on the left side of dash..thanks for any and all thoughts on this matter . |
| buickanddeere
10-25-2012 08:53:38
184.151.61.197
Re: 1975 2630 john deere low engine oil pressures in reply to Danny c, 10-24-2012 20:55:48
| As previously stated. Install a known working calibrated pressure gauge. Drain and fill with straight 50 weight Shell Rotela . Odds are the dealer rebuild was the economy version. New sleeves because the owner never changed the coolant. O'rings , gaskets pand bolt it back together. |
| Danny c
10-25-2012 12:54:47
166.147.120.152
Re: 1975 2630 john deere low engine oil pressures in reply to buickanddeere, 10-25-2012 08:53:38
| Yes the sleeves do look new, I'm sure the dealer just used the basic kit, and I don't know if that include the balance bushings. |
| teddy52food
10-25-2012 06:33:04
184.94.175.179
| What does the dealer say about it? |
| Danny c
10-25-2012 12:50:02
166.147.120.143
Re: 1975 2630 john deere low engine oil pressures in reply to teddy52food, 10-25-2012 06:33:04
| It is an old rebuild before I bought it , didn't know about the pressure until fixed the oil light. |
| buickanddeere
10-25-2012 13:34:39
209.240.127.249
Re: 1975 2630 john deere low engine oil pressures in reply to Danny c, 10-25-2012 12:50:02
| Given the age of the tractor and the price/cost/value. Just install an accurate robust gauge and keep an eye on the pressure. Run T1 50 weight. Install a new oil pump. Not really worth major input unless everything else is in new pristine condition. Given the obvious "care" the tractor had had previously. Make certain with a drain and flush that the trans/hydraulic is filled with Hy-Gard. Look for troubles both now and in a few hours trapped in the trans oil filter. I'll bet the water pump pulley and alternator pulleys are 37+ years old and worn. If the belt is tightened enough to avoid slippage. The alternator and water pump bearings will soon fail. 1-800-522-7448 for the operator manuals. There is a grease fitting or two in vital areas that needs a wee dab now and again. A $15 de-stroker screw and a coolant heater will ease winter starts. Don't use ether in those engines. They can't handle ether like a two stroke Detroit. Don't need broken piston rings. |
| Tx Jim
10-25-2012 04:21:59
67.142.163.20
Re: 1975 2630 john deere low engine oil pressures in reply to wijim, 10-24-2012 20:55:48
| It's possible that the balancer shafts bushings were overlooked on the overhaul.
| Danny c
10-25-2012 12:45:46
166.147.120.143
Re: 1975 2630 john deere low engine oil pressures in reply to Tx Jim, 10-25-2012 04:21:59
| I don't have a manual for this tractor yet, are these bushings major operation? |
| husker44a
10-24-2012 22:00:38
8.28.70.17
| Danny. If you can I would check your oil pressure with a known working accurate gauge. If the known gauge reveals the same. The I would guess it would be main or rod bearings or maybe both. Remove oil pan and plasti-gage all bearings. Good luck. |
| Danny c
10-25-2012 07:19:20
166.147.120.157
Re: 1975 2630 john deere low engine oil pressures in reply to husker44a, 10-24-2012 22:00:38
| Thanks for the reply , that"s what I thought , but it"s supposed to have a rebuilt engine , think I will start with that and the oil pump kit as well, and see what it does . Thanks |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
