| John Deere Tractors Discussion Forum |
Topic: Power hop
[Return to Forum]
| Author |
[Modern View]
| 4020deereboy
10-20-2012 01:27:18
205.185.95.11
8300 mfwd hops really bad has 20.8.42 rear and im not sure on the front. They are actually a metric size the front had 30 so I put em up to 36 didn't help went to 40 didn't help dropped the front down to 20 and that didn't help the rears are at 17 psi Any ideas ? Thanks Shaun |
[Reply] [No Email] | |
| 4020deereboy
10-21-2012 18:41:42
205.185.95.11
Re: Power hop in reply to 4020deereboy, 10-20-2012 01:27:18
| I have read the optimizing your 8000 series manual and it says to raise the front buy 2 psi over rated psi for axle loads until power hop stops and to leave the rear alone according to the tire size chart for the rear says I can run as low as 9 psi for for up to 17500 pounds rear axle weight with duals so should I lower the rear psi? Thanks Shaun |
| jason(ma)
10-21-2012 05:51:21
151.199.51.191
| I remember something about deere putting out a service bulletin on this back in the day. On our 8100 we"re running16.9 x30"s at 20psi and 20.8x42 at 18 psi 2 100"s on the front and 4 of those really thick rear wheel weights on the rear. We find the firestone tear at the pry notch if we go low with the air on singles with some of the 3 point imps we use. |
| gtx1967jewison
10-20-2012 05:45:31
174.253.129.23
| Way too much air. In our big tillage tractors (9560's) we run 6-7 psi. Obviously you can't go that low with your sizes but try less. They squat pretty good. Slippage will go way down also. And yes more ballast. The heavier the better. |
| Bradracer18
10-20-2012 04:28:26
173.215.8.237
| It could be largely due to your weight ballast. You need to configure your wheel/suitcase weights so you have approx. 65% rear weight and 35% front. |
| MSM
10-20-2012 04:10:38
75.197.77.187
| As was said below,check to make sure it has the proper size tires on it.If they are correct then I would ask the local dealer what they have done on other peoples tractors to correct a power hop problem. Soil conditions, the implement you are pulling,speed you are running, weigts/fluid in the tires all contribute to the problem. You may have to add/remove weights, adjust tire pressures,or worst case change out a set of tires. Don't keep trying to run it hopping,it will take a rear or driveline out. |
| leon
10-20-2012 03:09:41
173.27.205.97
| To start with, are you really sure you have front and rear tire sizes that are compatible with each other. If either set has been replaced sometime by someone, mismatched sizes could have been put back on. Check at your local JD dealership about tire size compatibility. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
