| Author |
[Modern View]
| toolz
10-14-2012 18:26:17
206.221.154.149
 Fired up my 4020 today after the change to the combine engine. The combine had sat outside for 10 years, so hearing it run was a relief. Only had 2025 hours on it, and it runs great. The pic is the bushing I made to change over from the CBC pump. I made it with a couple thou interference fit, and drove it in the block. Don't think it would ever move, but I drilled a 3/16 hole just above the tach drive and drove in a roll pin just to be safe. Got a few little details to clean up, but it looks like this swap is a success. She's a clean, straight tractor with good rubber, and I have less than $3000 in it at this point. Hopefully it will be a good one. |
[Reply] [No Email] | |
| Tx Jim
10-15-2012 05:51:54
67.142.163.24
Re: 4020 finally runs in reply to ben70b, 10-14-2012 18:26:17
| Quoting Removed, click Modern View to see
Tim
Do you have an hourly shop rate or a set charge per job?? |
| sideconsole4020guy
10-15-2012 04:48:49
216.249.194.192
Re: 4020 finally runs in reply to toolz, 10-14-2012 18:26:17
| Toolz, since you changed the cbc pump to the DB what are you going to do with the CBC pump and lines? IF you would sell them I would like to buy them for parts for the 2 CBC pumps I have on 4020's.
Thanks
Zach |
| toolz
10-15-2012 19:13:08
206.221.154.149
Re: 4020 finally runs in reply to sideconsole4020guy, 10-15-2012 04:48:49
| Zach- I will sell the pump and lines. Send me an email and let me know what they are worth to you. Thanks- Kevin |
| sideconsole4020guy
10-15-2012 19:55:50
216.249.194.192
Re: 4020 finally runs in reply to toolz, 10-15-2012 19:13:08
| Kevin, what is your email address?
Thanks
Zach |
| toolz
10-15-2012 22:04:43
206.221.154.149
Re: 4020 finally runs in reply to sideconsole4020guy, 10-15-2012 19:55:50
| Just click on "send email" on the bottom of my post. |
| sideconsole4020guy
10-16-2012 04:12:29
216.249.194.192
Re: 4020 finally runs in reply to toolz, 10-15-2012 22:04:43
| Send email does not show up for me on the bottom of your post, If mine doesnt show up my email is zach_vanwesten@hotmail.com |
| thurlow
10-14-2012 18:41:11
74.177.51.182
| Congratulations; with 2000 hours on the engine, it's almost broken in......... |
| larryanderson
10-15-2012 03:40:19
184.21.172.50
Re: 4020 finally runs in reply to thurlow, 10-14-2012 18:41:11
| Hard to find a $3000 4020.Just shows what can be accomplished if you are willing to do some work and have the ability to do it yourself.I have seen many tired tractor that the owner spends more than they are worth usually at a JD shop that charges $80+ per hour. |
| Tim S
10-15-2012 04:20:03
75.49.12.60
Re: 4020 finally runs in reply to larryanderson, 10-15-2012 03:40:19
| Yes it's tuff to come out ahead fixing up a worn out tractor with todays high priced parts, the local dealers around here are at $90 per hour now(these shiny new buildings with all the new trucks to go with them are expensive).. |
| jamie in il
11-23-2012 16:00:25
66.114.184.210
Re: 4020 finally runs in reply to Tim S, 10-15-2012 04:20:03
| need some help repowering my 67 4020 gas with a 1977 6600 combne engine, can you help??,,thanks |
| Tim S
11-23-2012 16:41:21
75.60.207.71
Re: 4020 finally runs in reply to jamie in il, 11-23-2012 16:00:25
| Yes i can help you, I have done several of them. If you are using the non-turboed 404 (4230 style engine) that is the best choice, tell me more, is the 4020 a sychro or power shift |
| Tim S
11-23-2012 16:40:58
75.60.207.71
