Yesterday's Tractor Co. Tractor Parts for All Brands
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Antifreeze out of the exhaust
[Return to Forum]
ffdfireman18
10-13-2012 07:04:23
65.183.175.241
I finally got my 45 A running pretty good. I plowed 2 acres with it and took the disc to it. The problem I"m having is it sat for probably two months now. I shut the gas off and ran it out when I parked it. I went to start it yesterday and it spit out what looks to be water out of the exhaust. Quite a bit all over the hood and dripping on the floor. After further inspection it had some antifreeze in it. I checked the coolant level and it wasn"t really low. About 1-2 inches down from the very top of the filler neck. Anything to worry about? Bad head or head gasket? Any help or comments are appreciated.
[Reply]   [No Email]
Mike M
10-14-2012 05:20:57
70.194.3.170
Re: Antifreeze out of the exhaust in reply to ffdfireman18, 10-13-2012 07:04:23
I'd retorque the head then premix some bars leak and dump it in and then go plow again. This stopped my B from weeping thru the gasket.
  [Reply]  [No Email]
Dandy Dave
10-14-2012 01:16:05
209.105.142.197
Did these still have the tubes for the push rods in 45? I had to replace the steel ones with the brass replacments in both my 39 A and my 37 BO. Also, I've seen hairline cracks in the heads where the coolant flows around the intake valve chamber. The last series of A's no longer had the tubes.
  [Reply]  [No Email]
JDseller
10-14-2012 00:36:39
208.126.196.144
My first JD tractor was JD "G". It would leak anti-freeze into the cylinders if it set more than a few weeks. I had the engine completely apart and check out. Nothing could be found wrong. I owned the tractor for thirty years it did it until I sold it and the new owner says it still does it.
My solution was if I was going to be using it in a month or so I just opened the pet cocks when I went to start it. It would blow the water out the pet cocks. For over the winter I just removed the spark plugs and filled the cylinders with diesel fuel. That would keep it from rusting the cylinder walls. I then just spun it over a few time and re-installed the spark plugs.
  [Reply]  [No Email]
jd b puller
10-13-2012 20:11:47
65.190.135.248
The manifold studs go into water too.
  [Reply]  [No Email]
donmyeil
10-13-2012 13:49:45
74.32.252.164
Might try retorque the head.,if its fresh overhaul. Sounds like seepege thru the gasket. Check oil for antifreeze there.
  [Reply]  [No Email]
husker44a
10-13-2012 08:37:36
8.28.70.17
Cracked head or head gasket
  [Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
