| John Deere Tractors Discussion Forum |
Topic: 70 Stuck
[Return to Forum]
| Author |
[Modern View]
| jdman(mo)
10-10-2012 08:57:41
64.49.150.124
Got this 70 in that was stuck, hoped it was varnish but turned out to be caused by water from gas tank. tried transmission fluid and acetone no luck. Had I might as well pull the block and have the piston pressed out or try some other solution. From looking at the carb and manifold there is a lot of rust.Tractor had no sediment bowl, or auto shutoff. Russ |
| Greenday
10-11-2012 04:55:39
204.185.166.101
Re: 70 Stuck in reply to jdman(mo), 10-10-2012 08:57:41
| Pull it apart. If its stuck that bad you will have to disassemble it to recondition it anyway |
| jdman(mo)
10-10-2012 18:37:24
64.49.150.124
| Thanks to all, will let you know when it ever gets tore down |
| JohnDeereJimOhio
10-10-2012 16:20:04
24.140.54.235
| I found you are a lot further ahead to just pull it apart. Check everything out and then you know what you are working with... I set my last block on saw horses and let it soak in ATF and Diesel for 3 days.. Then took a piece of hardwood and a sledge and drove them out fairly easy.... |
| teddy52food
10-10-2012 10:08:37
184.94.175.179
| If there is a lot of rust, just tear it down & do what you got to do. |
| jturbo10
10-10-2012 10:03:29
67.232.123.92
| In addition to the ATF you might want to build a spark plug adapter with shutoff valve so you can pressurize the cylinders with an air hose and then use the cutoff valve to hold the pressure against the cylinder and also put pressure on the ATF to free up the rust and get to the rings. I would try to pressurize to about 125 psi which should not do any damage to any components. Put the tractor in neutral and disengage the clutch and wait for the cylinder to free up. If you don't want to go through the trouble of building the adapter you might as well pull the block as you will have to clean up the cylinders, walls, heads, bearings, and check for cracks in the block. JMHO |
| old
10-10-2012 09:44:38
209.86.226.32
| This maybe a long shot but worth a try any how. Jack the front wheels up say about 18-24 inches. Then fill the cylinders with ATF and let it sit a week or so then try a 12 volt battery and short fast taps on the starter button and see if it pops free. The problem on the 2 cylinder JD tractor is that you can not fill the cylinder up to the point the ATF gets to the top of the piston so then you have that area that holds out. So by jacking it up the ATF covers the whole piston and then has a better chance of leaking down and around so it frees it up |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
