Yesterday's Tractor Co. New Parts for Old Tractors
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: No fuel from injection pump
[Return to Forum]
toolz
10-07-2012 13:51:30
206.221.154.149
My 4020 engine replacement is done, but I can't get the injection pump to work. I have bled everything, and have fuel to the pump. The engine is from an early 7700 combine, CBC633-26AL. The fuel shut-off has a faint click when I turn on the key. Is there a way to make sure it's opening? Any suggestions before I take it to the rebuilder?
First pic is the CBC pump, second is the DBGVC on the blown engine. Would like to change it over, but the mount is different.
[Reply]   [No Email]
sideconsole4020guy
10-08-2012 19:14:55
216.249.194.192
 Re: No fuel from injection pump in reply to toolz, 10-07-2012 13:51:30
What are you going to do with that CBC pump if you use the other one? i would be interested in the pump and lines if you would sell them?
Thanks,
Zach
[Reply]  [No Email]
donmyeil
10-08-2012 13:31:18
74.32.252.164
The later db pumps will fit the hole or use a bushing. I cut the bottom off of an old db and used it for a templaet and drilled and tapped holes . I never made a bushing so I dont know what was used or how it stayed in place without falling down .
[Reply]  [No Email]
Tim S
10-08-2012 14:52:22
75.49.8.217
 Re: No fuel from injection pump in reply to donmyeil, 10-08-2012 13:31:18
We make them with a thin lip at the top to keep them from sliding down...works out good...
[Reply]  [No Email]
Tx Jim
10-08-2012 04:36:54
67.142.163.21
 Re: No fuel from injection pump in reply to Kansas Man, 10-07-2012 13:51:30
IIRC this is the clamp required AR69420 CLAMP WITH PIN ADD 52.40 USD
[Reply]  [No Email]
Tim S
10-08-2012 04:47:35
75.49.22.23
 Re: No fuel from injection pump in reply to Tx Jim, 10-08-2012 04:36:54
Yes Jim that's the clamp,,I made a few using one for a pattern..the pin is not necessary..the clamp will hold it in place..
[Reply]  [No Email]
LJD
10-07-2012 15:36:16
75.213.81.16
The fuel shut-off solenoid on the C pump has two flat screwdriver slots on it. Two flat-ended screwdrivers will work to take it out. It just unscrews. Take it out and inside there is a little plunger and spring. If you take the plunger and spring out and then put the big piece back in - it is "run" position, all the time. You'll have to stall the tractor though - to shut it off.
I hope you realize that that C pump is obsolete and nobody in the USA has new parts to fix it. A few shops have used parts laying around and can patch those pumps up - but that's about it.
To put the better DB pump on the engine - you just need some adapters.
[Reply]  [No Email]
toolz
10-07-2012 18:29:04
206.221.154.149
 Re: No fuel from injection pump in reply to LJD, 10-07-2012 15:36:16
Thanks LJD. I did pull the solenoid out this afternoon- it"s working fine, and the pump is clean and full of fuel- just doesn"t put anything to the lines. Tim suggested making a bushing to mount the DB pump, and that will be the solution, since I know that pump is good. It will also look factory and hook up to the linkage.
Does someone make an adapter kit? It doesn"t look like it will take me long to do it, but if I can buy them, it will save some time.
[Reply]  [No Email]
Tx Jim
10-07-2012 13:57:03
67.142.163.24
 Re: No fuel from injection pump in reply to Hard Knocks, 10-07-2012 13:51:30
You can remove the fuel cutoff plunger but if engine cranks you'll either have to block off the air supply or ride the brakes in high gear to kill it.
[Reply]  [No Email]
toolz
10-07-2012 14:11:37
206.221.154.149
 Re: No fuel from injection pump in reply to Tx Jim, 10-07-2012 13:57:03
Jim- I would like to try that, but how does the plunger come out?
[Reply]  [No Email]
Tim S
10-07-2012 14:30:35
75.49.22.23
 Re: No fuel from injection pump in reply to toolz, 10-07-2012 14:11:37
You can make the old pump work by having a bushing made and a clamp style hold down, I have done this several times and worked out good.
[Reply]  [No Email]
toolz
10-07-2012 15:25:59
206.221.154.149
 Re: No fuel from injection pump in reply to Tim S, 10-07-2012 14:30:35
Tim- That sounds like a good idea. I happen to have a lathe and a chunk of aluminum that needs a home. Is the pump drive and height the same?
[Reply]  [No Email]
Tim S
10-08-2012 04:22:27
75.49.22.23
 Re: No fuel from injection pump in reply to toolz, 10-07-2012 15:25:59
I turn the bushing to a nice slip fit, "BUT" you need to leave a small thin lip on the outer top side so it don't try to slip down, seal it up as you go together, but first make your "C" clamp hold down and drill the holes insuring good fit first,,the shaft is the right length and the small lip will hold the pump up just a bit but not enough to hurt anything,,I got several of them running around here like this, working just fine...sure it's not just exactly right, but it still gets the feed ground...
[Reply]  [No Email]
toolz
10-08-2012 18:21:30
206.221.154.149
 Re: No fuel from injection pump in reply to Tim S, 10-08-2012 04:22:27
I thought I might just use a small pin through the bushing slightly into the pump to hold the bushing up, or drill through the block behind the tach drive for a roll pin into the bushing. Also thought I could make two hold-down clamps, similar to a distributor hold-down, for each side of the pump flange.
[Reply]  [No Email]
Tim S
10-08-2012 18:23:11
75.49.8.217
 Re: No fuel from injection pump in reply to toolz, 10-08-2012 18:21:30
The little flange is simpler...
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
