Leonard Dacus
I would appreciate some help with smoking problem with my old 51 A j.d. having a lot of excessive smoking on start up, once warmed up better but does not complete go away. Starts good, runs good but smoking is bad on startup
rebuilt motor last year, had block bored to .090" new aluminum pistons, has been ok until late. I removed plugs cranked over after sitting a couple days all i saw was plug on belt pulley side had a bit of oil around plug. thought i would aask for help before i do something wrong. At age 76 things are not as easy as they were when younger. one more thing looked inside radiator with engine running thought i could see air bubble up occasionally. thanks in advance.
