Topic: JD Idles Then Dies Roosa Master
[Return to Forum]
| Author |
[Modern View]
| rockinrog
10-07-2012 09:37:55
74.198.20.131
HI there, I have an older John Deere tractor and found a similar post on here where a user had an issue that was similar to mine. What happens is the tractor will start then within minutes it stops. His had a Roosa Master injector pump and similar to mine he was told to pull the timing window while running and if it runs perpetually it should likely be that the governor weight retaining ring fell to pieces.
I tried cracking the window on mine and while diesel came spitting out the tractor run flawlessly and with much more power! Now, is there anything I can do to fix this or should I look for other problems? I've never open an injector pump, haven't any manuals on it or the likes. I've found a place to send it too in Wisconsin for repair for around $350.00 so is that reasonable?
Any help is appreciated at this time...Thanks Roger. |
| LJD
10-07-2012 15:39:31
75.213.81.16
Re: JD Idles Then Dies Roosa Master in reply to rockinrog, 10-07-2012 09:37:55
| | To fix back to original, it takes a $15 seal/flex-ring kit, a new $8 bronze bushing (pilot tube), and a new housing-pressure-regulator for $10. $33 total in new parts to fix and about 2 hours bench time to take apart, fix and put back together. If you want to eliminate the rubber part that failed and upgrade to a better system - add $50 to the parts cost. |
| rockinrog
10-09-2012 16:51:26
74.198.164.227
Re: JD Idles Then Dies Roosa Master in reply to LJD, 10-07-2012 15:39:31
| Quoting Removed, click Modern View to see
Ya know, hearing this is isn't good LJD because I may be good at some things however opening my pump without a manual and your experience is a sure fire way to have your company over for supper and beer chuckle. I'm up in Ontario Canada if by chance one of you are however Sault Michigan is right across the bridge from me so shipping is easy enough.
I'm going to consider the Ebay add as I just started communication with the seller and should he state that he'll do the testing on the pump for his price then we'll that is pretty darn good. I am also going to call Al Baker from the above post... Thanks for this again Al..
Will update as I go... Thanks everyone, excellent forum btw and should there be a donate button here I'll do it. |
| Tim S
10-07-2012 14:28:11
75.49.22.23
| My pump shop, Columbus Diesel ,supply charges about $800 for this,, I wish Al was closer to me... |
| Al Baker
10-07-2012 12:24:53
65.183.168.227
| Your problem is a worn flex ring. I have rebuilt hundreds of these pumps. I charge 350.00 to steam clean and tear down the pump. inspect all parts and replace seal kit with flex ring. The drive tube is about 15 bucks if needed, and metering valve about the same. I charge 100.00 bucks to run this pump on a test stand to check fuel output, high and low speeds, and then check hydrualic advance. Then I pressure test the pump for possible leaks. A total of 450.00-475.00 for your pump to run like new, with a one year warranty. I do not cover the pump with cheap looking paint when finished. All pumps are polished and buffed out and look like something you would be proud to install and say you own. Al Baker 231.757.0064 |
| LarrySTN
10-07-2012 11:49:27
71.54.89.157
| $350 sounds high. Locally the cost is $200. Flex ring and gasket replacement takes about 1.5 hours, the seal/gasket kit runs about $75. |
| David G
10-07-2012 10:20:05
205.215.206.18
| $350 is very cheap, are they reputable? |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
