3010 throttle
What is the best way to tighten up the column throttle assembly on a 3010 gas? This one goes back to idle on its own due to governor spring tension. Something must be worn out, but I do not know what. Thanks in advance for any help you can give.
Open the door under the dash and tighten the bolt(parts key #13) on the brake lining
