| John Deere Tractors Discussion Forum |
Topic: 820 identity question
[Return to Forum]
| Author |
[Modern View]
| russ turner
09-29-2012 17:47:39
184.12.235.210
I looked at an 820 s/n 2xx that had a cast bottom below the grill screen. There is 2 forward facing 4 x 4 inch flat faces facing forward on each corner. iIs this a special model, after market part for a bumper, or ??? there wasn't an 'I' with the s/n Thank you RT |
| jd2cylman
10-03-2012 18:25:38
67.167.218.125
Re: 820 identity question in reply to cannonball, 09-29-2012 17:47:39
| Russ,
If the rims on this 820 have two ribs on them, then they must be the 34" hubs (or they're not the correct rims). For the 26" hubs, the rims only have one rib, and the rim and tire assembly get turned around to have the dish "in" or "out". In fact, I think the 34" rims were the same way. I'd have to look when I get home tomorrow. I had an 820 with 26" hubs and I sold the R1600R hubs and put on the R2522R hubs so I could use 20" rims for my new 23.1x26 tires and dish them in. Saved a lot of shed space. For the 830, Dad said no 26" tires.
Adrian |
| Rwolfejr
10-03-2012 06:19:02
67.163.184.160
Re: 820 identity question in reply to russ turner, 09-29-2012 17:47:39
| Before you go to all the trouble you should look at your local laws regarding hauling farm equipment. Most likely you will be legal hauling it just the way it is. In many states moving anything farm related down a road is covered under a section called "implements of husbandry" and will usually allow for overwidth. |
| russ turner
10-01-2012 09:54:42
184.12.235.210
| Wierddeere, The hitch looks like the one in your picture. Can the wheels be moved to the narrow setting, as it is now the tractor is over width for transporting. RT |
| WeirdDeere
10-01-2012 11:35:45
208.93.185.1
Re: 820 identity question in reply to russ turner, 10-01-2012 09:54:42
| | It MIGHT be possible, depending on what rims and center hubs are on the tractor. Some hubs will allow it, others won't. It won't be an easy job, you have to take the rims off and flip them around. If those tires are loaded, it could be a killer. There are two hub styles. The r1600R is narrower, and you probably don't have the room to flip the rims around without hitting the fenders. My 80 won't. IF it has 16 inch wide rims you can flip it, but I think most tractors had 20 inchers. Look at the center of the hub, note how the axle retainer sticks out.
The R2522R hub is a little wider, and there should be enough room to flip the rims to narrow. Look at the center of the hub, note how the axle retainer is recessed slightly (ignoring the weights, couldn't find one without!)
Brandon |
| russ turner
10-01-2012 11:56:34
184.12.235.210
Re: 820 identity question in reply to WeirdDeere, 10-01-2012 11:35:45
| Weirddeere, The rims on the 820 have an inner and outer ridge for mounting wihich would narrow the width up i'm gussing about 5" per side. They might be later will fit rims. It looks like the extra drawbar brackets you pictured could be removed which would surley solve any clearance problem. Thank You RT |
| russ turner
09-30-2012 17:38:04
184.12.235.210
| That"s it. I found a web site for 830 industrial with photos that also said that some 820"s had extra renforsment added to the drawbar assembly for scraper applications. The 820 in question has a much larger frame suporting the drawbar. Obtaining this one looks like it will take time, wish me luck. RT |
| WeirdDeere
10-01-2012 01:35:04
208.93.185.157
Re: 820 identity question in reply to russ turner, 09-30-2012 17:38:04
| | I'd bet the drawbar looks like this?
Sounds like you found an interesting 820. If you get it, I'd love to see pictures! I'm the WeirdDeere.com guy Brandon |
| russ turner
09-30-2012 17:36:36
184.12.235.210
| WeirdDeere
09-30-2012 16:52:42
199.87.176.147
| | if the front end support you describe looks like Rwolfejr's tractor, you have an industrial front end on your 820. Really not common at all to see it on an 820. May have been retrofit on there, or possibly factory. Brandon |
| Rwolfejr
09-30-2012 07:42:47
67.163.184.160
| That's an industrial front end. Look at your axle and see if it's flat across the bottom as well. If it is you have the industrial pan and axle assembly.
It'll look like this...
| bill mart
09-30-2012 06:31:07
69.204.65.189
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
