| John Deere Tractors Discussion Forum |
Topic: JD 3020 Diesel
[Return to Forum]
| Author |
[Modern View]
| Clint Barnhart
09-28-2012 16:54:37
216.145.151.227
I have a 3020 JD Diesel. I replaced the fuel sending unit and the fuel gauge reads full no matter how much fuel is in the tank. The fuel gauge is new. Any ideas on what I can do fix this? |
| LonM
09-29-2012 19:04:09
69.165.30.214
Re: JD 3020 Diesel in reply to Clint Barnhart, 09-28-2012 16:54:37
| I would add to make sure you have the correct sender for your year of 3020, as the early vs side consoles had different ohm specs in the senders. Ours always read full too and I fought that for a long time before I double checked the part number! Good Luck, LonM |
| Tim S
09-28-2012 19:34:10
99.159.254.50
| Yes, you "must" be sure you have the proper gauge to match the system, tell me is it 12 or 24 volt, console or not..and I"ll give you the correct part numbers... |
| jddave
09-28-2012 17:33:19
67.84.199.187
| You say your gauge is new. Is it a John Deere part or another replacement item? Some John Deere gauges replace the original and do not appear original nor do they wire the same requiring a work-around to ground a terminal plus hot wire and sender wire. Make sure the polarity is correct also. You can check the gauge by grounding the sender terminal. With and without ground and the gauge should read alternately "full" and "empty". Then check the resistance of the sending unit from "full' to "empty" with a multimeter set to OHMS. There should be a range of roughly 20-60 ohms I think. Any questions ask Jerry at Evergreen Restorations advertised in Two-Cylinder. Of course another issue is a short in the sender wiring which would ground the signal but this is not common. The sender housing must be grounded to the tank and tractor. Check for complete ground with a multimeter. I always bench test the fuel gauge with the sender before installing them. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
