| John Deere Tractors Discussion Forum |
Topic: John Deere H Hard Starting
[Return to Forum]
| Author |
[Modern View]
| indiana george
09-28-2012 16:43:46
76.16.114.221
I have a a 1940 John Deere H. I am having a lot of problems hand starting it, and i can only get is started by pulling it. When I have checked the spark on the magneto, the spark color is blue so I know it has a good strong spark. I have also replaced the spark plugs. When i do pull start and get it going it is back firing like crazy. I timed the tractor by the book, So I am assuming it is timed correctly. Anyone have any ideas? is it not timed correctly? Thanks any input is appreciated cause i am stuck!! |
| buck eye al
10-02-2012 16:07:40
168.251.194.11
Re: John Deere H Hard Starting in reply to indiana george, 09-28-2012 16:43:46
| | Dad's first tractor was an H and he too had similar chronic starting problems ewven with good spark. My brother and I tinkerd with it when he was away at a seminar and found the plate that covered the LP tank shaped hole in the lower half of the choke plate was broken off. We scrounged up some sheet metal then cut, bent and filed it to make a new plate for it. The spring was still there, just the bottom half of the flapper was gone. That was near 50 years ago & to this day if it doesn't start in just a few turns it's a mag problem or outta gas! Hope that helps. |
| Mike M
09-29-2012 18:44:24
70.194.0.91
| I have had more then one H have intake manifold gasket leakage cause hard starting and poor running and needing to have choke on to run. |
| greenday
09-29-2012 05:52:40
216.145.156.69
| sounds like a ignition problem |
| Anthonyu
09-28-2012 18:01:05
108.204.10.97
| Sounds like your mag is weak anytime I have had to pull start the tractor the mag was weak or needed a rebuild. Try cleaning your points in your mag first the next thing I would do is pull the mag set cylinder one to top dead center the best way to do it is pull the plug out and look in the hole for the piston coming up to TDC then once you get that set the mag back on the tractor. You should be ready to fire if it backfires reverse the plug wires let us known how you make out. |
| J.Wondergem
09-28-2012 17:23:21
70.194.5.227
Re: John Deere H Hard Starting in reply to MTC, 09-28-2012 16:43:46
Are you sure the choke is working? |
| Indiana George
09-30-2012 08:02:13
76.16.114.221
Re: John Deere H Hard Starting in reply to J.Wondergem, 09-28-2012 17:23:21
| The mag has good spark. When you look at the spark is a blue color so i know it is firing hot and it was rebuilt 2 years ago. yes we have also choked it. The crazy thing is that once it is warmed up it is easier to start as well I could even hand start it when it was warmer. I have read something else about the intake manifold being bad as well? That possibly when the tractor is warmed up the intake manifold expands making it easier to start if there are any cracks in it? any ideas? |
| indiana george
09-30-2012 08:03:44
76.16.114.221
Re: John Deere H Hard Starting in reply to Indiana George, 09-30-2012 08:02:13
| What i meant so say was the intake manifold gasket, not the intake manifold. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
