What is the easiest way to remove the load control shaft bushings on a JD 4020?
Every year without fail, one side will suddenly start leaking oil. The bushing on that side doesn't appear to have much wear but I'm at wits end as to why its always the same side and why the seal holds about a year then starts dripping constantly. I figure I might as well bite the bullet and replace the bushings and seals. Shaft is good.
