Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Help... 820 with no power
09-25-2012 12:23:50
I have a '72 JD 820 3cyl diesel tractor. It starts fine, but after about 7 - 10 minutes, it starts to lose power, and will stall. It does this sitting at idle or when under load. As it starts to lose power, increasing throttle doesn't change how it runs. It stalls. After a few minutes, it will start right up... 7 -10 minutes later, it stalls again. I have bled the system and changed both fuel filters and cleaned the bowls. Is it an injector pump issue or injector issue?
Tx Jim
09-25-2012 12:45:45
 Re: Help... 820 with no power in reply to nylon4020, 09-25-2012 12:23:50
Check the fuel return line and return fitting at the inj pump for blockage. Have you checked that to determine good fuel flow from tank to inj pump? Is fuel cap venting??
This post was edited by Tx Jim at 12:47:51 09/25/12.
