| John Deere Tractors Discussion Forum |
Topic: JD 2630 Thoughts Comments??
[Return to Forum]
| Author |
[Modern View]
| Ohiohills
09-22-2012 11:05:32
70.192.207.60
I've recently acquired, at a very reasonable cost, a 1974 JD 2630 diesel, wide front end. It's in pretty good condition, but has nearly 6,000 hrs on it. I was told it is considered a "utility" tractor, but I'm not sure what that is supposed to mean as I'm not familiar with John Deeres much newer than about 1955. So, I was wondering if some of you JD experts could give me some thoughts and comments on this model. Is the 2630 considered a reliable tractor? Any common problems? Any issues I should be aware of? Typical uses for this model? Would it be reasonable to fit this with a front-end loader? Any general advice/comments will be appreciated. |
| Larry Davis
09-22-2012 18:13:12
75.105.90.31
Re: JD 2630 Thoughts Comments?? in reply to Ohiohills, 09-22-2012 11:05:32
| I have owned a 2630 for a little over twenty year now and have really liked it allot. I am the second owner and the tractor now has over seven thousand hours with one overhaul. At sixty five hundred hours a 0 ring on a cylinder sleeve started to leak so I had the engine overhauled at that time. The tractor is a row crop utility having 15.5x 38 rear tires and rack and pinion axels. It came with a John Deere 145 loader that his worked well over the years. At 70 hp the tractor has handled any job I needed done. It isn"t bad on fuel but I don"t do any tillage anymore either. Makes a very nice haying tractor. Mine has the Hi Lo transmission making for 16 forward speeds. For loader work it needs added ballast to the rear, either fluid or weights but has to have something to handle round bales. Do what B&D says before you make the deal. It needs care like any machine but will pay off if done right. I would definately look seriously at a 2630 if in the market. Like most all utility tractos you sit lower with the transmission between your legs and that can be hot in summer but other than that it has been great for me. Good luck. Larry |
| faillafarms
09-22-2012 17:31:19
137.36.51.20
| we got one at home- rebuilt the engine at 6800 hours- bad balancer shafts...
runs like a raped ape now. great machine got a 48 loader on it. reliable machines and run really good. got big 12.5-15 tires on the front end- really helps with the loaders weight. if you mount a loader used a closed center valve.
-Nick
| Tx Jim
09-22-2012 16:41:36
67.142.163.26
Re: JD 2630 Thoughts Comments?? in reply to Jeff in TX, 09-22-2012 11:05:32
| Swept back frt axles lessens a tractors stability because of shortening the wheelbase BUT I've seen many JD tractors with sweptback frt axles that had frt end loaders on them. |
| Frankinwalton
09-22-2012 16:09:28
166.249.198.67
| The 2630 could be had with swept back front axle. Front end loaders are not recommended with the swept back front axle. |
| Ohiohills
09-22-2012 19:07:30
70.192.193.0
Re: JD 2630 Thoughts Comments?? in reply to Frankinwalton, 09-22-2012 16:09:28
| Fortunately, the 2630 I got has a straight front axle. |
| buickanddeere
09-22-2012 14:21:31
70.76.174.113
| Excellent if maintained, like any other machine. A headache if abused. Test the coolant ph and additive strength. Not talking about level of freeze protection . Inspect trans oil filter, clean trans screen and get back to us. A complete trans oil change maybe a good idea. 1-800-522-7448 for the operator's manual. |
| JD2ACWD
09-22-2012 11:50:54
64.33.153.13
| had one on my dad's farm for years great little tractor,no problems at all with it,one of my relatives still owns it,we had a john deere 146 loader on it. |
| Tx Jim
09-22-2012 11:31:58
67.142.163.26
Re: JD 2630 Thoughts Comments?? in reply to husker44a, 09-22-2012 11:05:32
| A frt end loader will work fine on a 2630. Be sure and get a closed center hyd control valve. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
