Yesterday's Tractor Co. The Right Parts, Right Away
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: 620 JD cam noise?
[Return to Forum]
DGK
09-17-2012 17:22:02
70.194.65.176
I have banging noise sounds like comming from cam area. Pulled gov. completly out found 3 bolts on cam gear loose,still have noise but if u put gov and hyd pump back in it gets twice as bad. Thanks for any Ideas. Doug
[Reply]   [No Email]
Fred from Mo
09-17-2012 19:56:37
70.195.64.236
 Re: 620 JD cam noise? in reply to DGK, 09-17-2012 17:22:02
My experience is only with a 60 so take it for what its worth but can you pull the flywheel side cam bearing houding to check the cam bearing?
[Reply]  [No Email]
DGK
09-17-2012 20:34:18
174.255.82.116
 Re: 620 JD cam noise? in reply to Fred from Mo, 09-17-2012 19:56:37
Pulled clutch side cover off cam bearing look good but don't understand spring load on cam bearing. flywheel side looks good to. I notice 1 pushrod bearly rubs head but can't feel anything.
[Reply]  [No Email]
Fred from MO
09-18-2012 09:38:48
69.55.155.226
 Re: 620 JD cam noise? in reply to DGK, 09-17-2012 20:34:18
The spring on the clutch side pre-loads the bearings on the camshaft to keep the proper position/bearing crush etc. It needs to be in place when you re-assemble the first reduction gear cover. Can you pop the cover and look at your oil pump drive shaft. Are you getting good oil pressure? The cam, cam bearings, races, cam gear, oil pump, oil drive shaft all work as one, so I am just guessing that you have something going on in there not right.
[Reply]  [No Email]
DGK
09-18-2012 18:06:19
70.194.69.53
 Re: 620 JD cam noise? in reply to Fred from MO, 09-18-2012 09:38:48
Thanks Fred for reply! I know the spring preloads bearings but the cam gear is beveled gear I think. Why wouldn't they just shim it solid? Anyhow I have good oil pressure, spring is in right. I drove it to other place and will bring it back this winter when I have more time. But still need some more insight on it if anyone has any Ideas. Thanks Doug
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
