| John Deere Tractors Discussion Forum |
Topic: 4010 diesel problems
[Return to Forum]
| Author |
[Modern View]
| jdjoe71
09-15-2012 20:09:48
206.72.24.56
4010 diesel has a fair amount of blowby and pushing oil out blowby tube. dont know much about the engine. but starts and runs real good. am i looking at an overhaul or head job? or what else could be causing this. also the tractor will lose its power steering all at once. brakes and other hyds will work fine. what could be causing that. thanks. joe. |
[Reply] [No Email] | |
| donmyeil
09-17-2012 05:13:48
74.32.252.164
Re: 4010 diesel problems in reply to jdjoe71, 09-15-2012 20:09:48
| That engine has a ventilator pump on it . Has the oil been changed and what has it been doing the last few months ,chores and piddling around can cause a moisture build up and the vent pump makes this look bad. I would work the tractor and see what oil consumption is . You can take the tappet cover off and learn a lot . |
| jdjoe71
09-17-2012 08:06:48
206.72.24.56
Re: 4010 diesel problems in reply to donmyeil, 09-17-2012 05:13:48
| what do i look for by taking valve cover off? i have seen the ventilator pump line crimped shut before on other tractors. why do they do that? this tractor didnt get worked very hard. lots of tractor rides. |
| donjr
09-16-2012 13:27:07
71.248.83.169
| For as much work as you're gonna do already, and as long as the head is gonna take a trip to the machine shop for a few days, you might as well do an in-frame on the engine. New pistons and liners, a fresh head, and that tractor will give you many years of good service. |
| David G
09-16-2012 09:24:33
205.215.206.18
| OH as other suggest. I would not just grind the valves, because if there is seat wear you will drop compression. There is a spec on valve height. |
| larryanderson
09-16-2012 05:03:00
184.21.172.50
| Just as well completely O.H.it using good parts and have it done right and it will give you years of service. |
| Tim S
09-16-2012 07:17:55
75.49.18.96
Re: 4010 diesel problems in reply to larryanderson, 09-16-2012 05:03:00
|  I'm with Larry, pull it down and do it right, you most likely have a piston scoring, it will soon seize and take out the rod bearing and maybe even the crankshaft, as for the steering, the valve needs cleaned and re-calibrated by some one that understands them, I have a way to do that here in my shop and bench test it to be "sure" it's right.. |
| Tx Jim
09-16-2012 04:03:40
67.142.163.20
Re: 4010 diesel problems in reply to Marty Whitworth, 09-15-2012 20:09:48
| I think reworking the cyl head would make blow-by worse not better. New pistons & liners is the only cure for blow-by. If only the steering quits then I think control valve under steering wheel would be the problem. |
| Texasmark1
09-16-2012 07:24:21
67.142.175.24
Re: 4010 diesel problems in reply to Tx Jim, 09-16-2012 04:03:40
| Agree on the head rework comment. With new valve seating surfaces, the combustion pressures rise and do as you said. Years ago dad had a '66 Chev V8 and it needed a valve job. Got the valve job and lo and behold then it needed rings. I assumed that the guy that did the work left some lapping compound on the seats, but later learned what I just said. Mark |
| Texasmark1
09-16-2012 07:24:07
67.142.175.24
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
