Yesterday's Tractor Co. Fast, Friendly Parts Service
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: 720 pony motor
[Return to Forum]
cowman74
09-12-2012 18:36:51
71.240.222.71
I have been working on the pony motor for a while. I have it running but the issue now is that the fuel wont flow out of the fuel tank to the carb. I have played with the fuel shut off and that didnt work. The only way I can get it to run is to pressurize the tank but as soon as the carb runs out of fuel it stops running. does anyone have any ideas? I"m going to a pull on Friday and Saturday.
[Reply]   [No Email]
F-I-T
09-14-2012 10:49:52
184.6.240.123
Re: 720 pony motor in reply to cowman74, 09-12-2012 18:36:51
You know, that really sounds like a pugged carburetor bowl vent to me. That's a reach, but for the fuel not to run into the bowl without pressure is pretty odd if everything else is clear. If you have the hood off, can you remove the bowl plug and see if it runs fuel through then?
  [Reply]  [No Email]
Dan in Ohio
09-13-2012 17:44:58
67.54.209.132
Cowman,
The first thing I do when starting my cranking engine is check the oil and fill the gas tank. Yes I mean fill her up, you are stetting yourself up for some real head aches if you do not do this first. You should have a pencil size flow through the fuel hose. John Deere still has them as have bought a couple of them in the last two years (about $40 I think). Have also made my own as mentioned, your choice. The next thing after you solve the fuel issue is to run a jumper wire from the starter to the distributor, this makes them all run better.
  [Reply]  [No Email]
Blksmok
09-13-2012 17:42:37
67.209.80.17
Remove the fitting on the bottom of the pony engine fuel tank and push a phillips screwdriver up the opening to push out the screen inside the tank. Put a small in -line filter between the tank and the pony engine carb.
  [Reply]  [No Email]
Cowman74
09-13-2012 16:53:22
71.240.222.71
I redid the hose today with 3/8 hose and fittings. The first time I cranked it it ran great. I tried it again and it doesn"t have enough fuel. Any other ideas?
  [Reply]  [No Email]
Duane(Pa)
09-13-2012 16:27:41
71.58.106.51
You can get 1/8" NPT fittings to put regular hose barbs on the sediment bowl and Carb. I did just that, and put a simple on-off quarter turn shut off from a small engine shop on mine. I was sick of gas in the crankcase. leave it on for the pull and if you stall out you can crank the pony. I really like to store it with a dry carb. so I shut it off when finished for the day.
  [Reply]  [No Email]
Bob Harvey
09-12-2012 19:54:56
209.91.107.156
Your local parts store should have that clear braided hose in your size. I d try that to see what is going through.
  [Reply]  [No Email]
Old Popper
09-13-2012 04:53:45
216.51.202.134
Re: 720 pony motor in reply to Bob Harvey, 09-12-2012 19:54:56
You would have to do some creative plumbing. That fuel hose has copper tube (I think 3/16) crimped into the ends, and uses ferrules and nuts for connection. If you get the hose from Deere it is close to $50. Don't ask how I know!
  [Reply]  [No Email]
James Lieb
09-12-2012 18:53:33
72.175.8.141
I replaced my hose several years ago,I bought a new one at Deere,don't know if they still have them or not.
  [Reply]  [No Email]
James Lieb
09-12-2012 18:49:58
72.175.8.141
Your rubber hose is collapsed,between gas tank and carb,take hose off at carb,check fuel flow,if that is not the problem,check for obstruction at the carb inlet.
  [Reply]  [No Email]
Old Popper
09-12-2012 18:45:28
216.51.202.134
Is the hose from the tank to the shutoff open and clear? I had to replace the hose on mine about a year ago because the gas wouldn't flow fast enough to keep it running. I still have to have the tank over half full to get it to run good.
  [Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
