Yesterday's Tractor Co. We Have the Tractor Parts You Need
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: H 3 way fuel valve
[Return to Forum]
JD Gimpl
09-12-2012 10:36:57
174.253.192.227
Hello Everyone
My 3way valve leaks gas into the carb when off. I heard that
there is a packing to replace but when looking at the parts
book I only see a gasket for the nut at the end. Anyone know
the part number for the packing or what I can do to keep this
from leaking.
[Reply]   [No Email]
Resting Relics 1
09-13-2012 05:10:23
24.151.93.80
Re: H 3 way fuel valve in reply to JD Gimpl, 09-12-2012 10:36:57
Hey JD Gimpl,
I believe Steiner now sells one with seals in it. This is a common problem especially with the newer gasoline. Best thing is to use the bowl shut off after setting the valve where you want it and tighting up the cap nut pretty tight. Good Luck!
John
  [Reply]  [No Email]
F-I-T
09-12-2012 14:35:56
184.6.240.123
If you want to get one leak free, you really have to add a few o-ring grooves. The one on the on the end around the shaft is sort of optional. I lap evertything first with Clover lapping compound. They won't drip and will work real smooth if you install o-rings. Sorry for the crude sketch.
  [Reply]  [No Email]
John T
09-12-2012 13:23:11
216.249.82.117
As I recall our friend the Frankster aka FIT has a good handle on this question, I also have used valve grind compound to lap them in and added that big outer gasket n got them to seal good AND IF I ONCE GOT ONE TO SEAL I NEVERRRRRRRR TURNED THEM AGAIN as I never saw a need to switch from gas to fuel and instead used the sediment bowl as the shut off....
John T
  [Reply]  [No Email]
Mike M
09-12-2012 12:48:38
24.140.0.120
Lapping the valve will help,but they will always leak some by internally by design
  [Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
