Yesterday's Tractor Co. Same-Day Parts Shipping Available
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: JD H Power Lift
[Return to Forum]
jbennage
09-10-2012 09:47:27
70.192.130.114
I have a 1941 JD H. It did not come from the
factory with Power Lift option. I know where I can
get a complete Power Lift hydraulic pump. What
besides a hydraulic cylinder and hoses, would I
need to put this on my tractor.Thanks
[Reply]   [No Email]
rusty wheel
09-10-2012 18:21:06
75.180.23.218
 Re: JD H Power Lift in reply to jbennage, 09-10-2012 09:47:27
jbennage, I rebuilt a 1945 H. In the process I removed the hydraulic pump and related parts, including the governor shaft and the left side governor cap that has the hole for the longer shaft. My name is bill and my phone number is 614-561-9454 If you're interested. Call anytime.
[Reply]  [No Email]
dan_41jdh
09-10-2012 15:46:41
24.149.8.64
jbennage, the 1941 model year for the model “H” began with S/N 20615 and ended with S/N 35698, so we’ll assume your tractor falls in that range. At S/N 27000 the longer governor shaft became standard equipment.
So if your tractor is truly original and is earlier than 27000, the governor shaft will have to be replaced – which can be a challenging task without the proper tools. After S/N 27000, the Power Lift is essentially a “bolt-on” that replaced the LH governor bearing housing, but with either early or late 1941 model year tractors, one still needs to maintain fan gear alignment which can be a real problem since the LH governor bearing housing positioning (via shims between the governor housing and the LH governor bearing housing) controls some of the fan gear alignment.
The Power Lift for the model “H” was introduced as optional equipment in December 1940, right around the time that S/N 27000 was built. But the Power Lift was made to fit back to the earliest models. If you were back in 1941, you could order a kit (AH915R) that included the Power Lift and all parts necessary for field installation to tractors built before S/N 27000. And that kit did include a replacement Power Shaft shifter lever (AH925R, casting number H876R) that Frank mentioned which fitted underneath the Power Lift housing. If your tractor doesn’t have a Power Shaft, you don’t need to worry about that part.
The link below is for a thread some years ago that discussed some aspects of the Power Lift for the model "H"....
[Reply]  [No Email]
lfnel
09-11-2012 03:47:45
173.27.205.97
 Re: JD H Power Lift in reply to dan_41jdh, 09-10-2012 15:46:41
Dan, After all the exchanges here lately about H governor housing/fan drives, I'm glad you waved the caution flag a bit here. The additional load presented by a hydraulic pump on the gears and bearings in the governor housing could exacerbate already existing conditions.
[Reply]  [No Email]
Cockbird_Hunter
09-11-2012 04:12:50
12.152.193.133
 Re: JD H Power Lift in reply to lfnel, 09-11-2012 03:47:45
I have tore down a few H's in my time & shown below is typical governor shaft "twisting" caused by hydraulic pump being drive from governor shaft.
[Reply]  [No Email]
F-I-T
09-10-2012 09:49:08
184.6.240.123
Pretty sure need the longer governor shaft, but I am away from my reference manuals.
[Reply]  [No Email]
jbennage
09-10-2012 09:55:11
70.192.130.114
 Re: JD H Power Lift in reply to F-I-T, 09-10-2012 09:49:08
Ahh....yes, that would make perfect sense otherwise the
pump would be more or less a "hood ornament", so to
speak. Thanks F-I-T
[Reply]  [No Email]
F-I-T
09-10-2012 09:55:36
184.6.240.123
 Re: JD H Power Lift in reply to jbennage, 09-10-2012 09:55:11
I think they even call out a different pto lever that is bent to fit around the hydro unit...if you have pto.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
