| John Deere Tractors Discussion Forum |
Topic: Painting tractor wheels.
[Return to Forum]
| Author |
[Modern View]
| Nathan Kapp
09-08-2012 19:11:41
174.59.239.73
Hey Guys,Im painting my JD 38" rims and centers this week. How much paint do I need to buy? I am using JD yellow from the dealer with thinner at a 1 part thinner to 10 parts paint ratio as the can suggests. Will 2 qts of yellow and 1 qt of primer do both rear rims and centers? Thanks. Nate |
| pbb
09-09-2012 19:10:05
216.163.26.175
Re: Painting tractor wheels. in reply to Nathan Kapp, 09-08-2012 19:11:41
| I would buy a gallon. My tractor has spokes on the back and solid on the front. I bought 2 qts and that wasnt enough. I had to go back and buy some more paint. That JD dealer paint is thin.We used very little thinner on it. We started shooting it strait no thinner with a gravity feed gun. Good luck. |
| 5020s rock
09-09-2012 11:33:04
24.14.134.90
| i would just buy a gallon. last time i bought paint it was like 18/qt and 45/gal. i have used primer and not. like the one guy said,i spray 1 coat wait awhile and spray another/or two. never had issues. depends if its ideal weather....85 degrees/good sun/low humidity... it dries quick. i have painted when its 90 and 70...prefer the heat. we use a zahn cup at work,good idea. paint does vary hugely between batches--fyi. |
| F-I-T
09-09-2012 10:29:13
184.6.240.123
| Quoting Removed, click Modern View to see
Any of you guys ever use a viscosity cup? You reduce paint based on its rate of flow at a particular temperature, then use a reducer that boils off at the correct rate at that temperature. You don't cut paint by a ratio. It's vastly different from the low range of application temperature to the high end. The flow can even vary with the paint batch to batch.
Don't forget the induction period. Some paint/hardener combinations need to rest in the cup after mixing just to infuse, BEFORE you spray.
I was taught by a fellow that sprayed semi cabs, Ryder trucks, and almost every UPS truck in the nation at one time, from acrylic enamel to Imron to Urethane. He said "Cut your paint to 30 seconds and you'll always have consistent spray application". That, and strain the paint well before you put it in the cup. And, BTW, and IMHO, you are spending almost as much as much on Deere synthol enamel, which was introduced on cars in 1934, as you would on DuPont or PPG urethane, which is current science. When you put that isocyante hardener in Deere enamel, it's just as dangerous as modern base/clear, or urethane, with a ton less durability. Don't fool yourself. |
| husker44a
09-09-2012 08:15:52
8.28.70.17
| I wire wheeled mine first. Then used JD primer. One quart. Then I used JD Yellow I think one quart also. I strained my paint sprayer 3/4 paint then added rest hardener.Mix well. No thinner at all. Spray one coat wait 20 minutes to get a flash on the paint. Then spray another coat. Will make the paint shine like chrome. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
