Yesterday's Tractor Co. Compare our Prices For Parts
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: john deere b got hot
[Return to Forum]
730johndeere
09-08-2012 11:24:10
64.12.117.12
was plowing with B engine temp got to 230 did it hurt motor why is it over heating it a 1950 with no water pump
[Reply]   [No Email]
jd b puller
09-17-2012 17:35:07
65.190.135.248
 Re: john deere b got hot in reply to 730johndeere, 09-08-2012 11:24:10
Is it actually overheating? Or just hot in the block/head.
If the water is hot on both sides of the radiator you may have an obstruction.
Is the timing way out of whack? If you're retarded, you're gonna be hot.
[Reply]  [No Email]
Ken11487
09-13-2012 19:04:53
64.66.236.36
What type of antifreeze is in it?
When I got my '36A it did the same thing running a threshing machine and even got hot doing nothing in the July heat. Turns out the last owner put the red permanent antifreeze in it and it was not boiling and circulating. Put straight water in it and it works right now. May try the water glycol mix yet. Have to keep it in the shop when it freezes.
[Reply]  [No Email]
donjr
09-13-2012 18:22:16
71.248.83.169
Make sure your shutters are in the 'open' position---
[Reply]  [No Email]
gtx1967jewison
09-08-2012 21:47:32
174.253.133.67
Thats not hot enough to hurt anything. IF your gauge is accurate. Usually the radiator core is scaled up with lime or rust from tunning straight well water & needs replaced.
[Reply]  [No Email]
BushogPapa
09-08-2012 18:49:01
173.88.51.117
Does it have Anti-Freeze in the radiator..??
If it does, it may not have even Boiled..
If it didn't Boil Hard and the water level got low, it should be ok..
With the Hand-Operated Shutters, I imagine ALL of them got hot at one time or another..!!
Without a water pump, sometimes you needed to drop down a gear, to keep the temp lower in Summer Heat..
Was the Coolant level high enough for the water to actually Circulate..?
It must be near the top of the "Dam", below the radiator cap or the coolant will not be able to circulate..
Have you looked to see if the fins need flushed out..?? Could be they are packed with chaff..
Ron..
[Reply]  [No Email]
pbb
09-08-2012 13:06:11
216.163.26.175
I know a guy that got his hot plowing too.It was a unstyled B. His tractor started smoking blue smoke after that. He said he was going to have to put rings in it. If yours dont smoke you might be alright.Your radiator may be partily stoped up or your head and block passages could be as well.
[Reply]  [No Email]
730johndeere
09-24-2012 14:25:08
205.188.117.12
 Re: john deere b got hot in reply to pbb, 09-08-2012 13:06:11
if keeps getting hot will try acid thanks
[Reply]  [No Email]
730johndeere
09-17-2012 14:56:26
64.12.117.12
thanks for all the help tractor smokes a little but thinks it normal i have had it full of water and full with mixed anti freeze still seems to want to get hot with both i flushed it many times got lots of rust out also cleaned outside of radator very well now still gets to about 180 when its not even working just driving around is there an eazy way to clean the block passages and inside radator or do you have to replace and pull everything apart
[Reply]  [No Email]
F-I-T
09-17-2012 16:09:34
184.6.240.123
 Re: john deere b got hot in reply to 730johndeere, 09-17-2012 14:56:26
You could try a gallon of Phosphoric Acid (not the much stronger Muriatic Acid, which would probably eat through an aging radiator core, and give off a lot of Chlorine gas). The Phosphoric Acid will reduce the red rust to inert black oxide, should cause those flakes to jiggle to the bottom, and slowly dissolve calcium carbonate (hard lime scale), Tearing them down is most always best, but for a few bucks, you might at least improve it quite a bit. The risk is that it might promote a leak in one or more places. You can let it in for quite a few days, and getting it up to temp would not be a bad idea, though watch out as it might foam up like a soap.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
