Yesterday's Tractor Co. Compare our Prices For Parts
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: JD 60 Governer Surging?
[Return to Forum]
NoDakInMN
09-05-2012 20:06:21
76.10.68.191
After I replaced the head and mainfolds on the 60 I aquired this spring, I fired it up and it ran kind of rough and I thought that the carb needed cleaning. But on closer examination, it seems that the governer is surging as it speeds up and then slows down and this is in time with the throttle arm opening and closing the throttle plate. When I hold the throttle arm still, the engine evens out and runs at a steady speed.
Any thoughts on what is causing this?
[Reply]   [No Email]
NoDakInMN
09-06-2012 22:21:13
76.10.68.191
Re: JD 60 Governer Surging? in reply to NoDakInMN, 09-05-2012 20:06:21
While a drizzle made it hard to do a complete check, I was not able to restrain myself and I removed the throttle rod and advanced the speed lever and the throttle plate to wide open and lo and behold it aligns with the hole and is not 1/2 hole short. I cannot wait to make the adjustment and see the result!
Thanks!
This post was edited by NoDakInMN at 22:22:30 09/06/12.
  [Reply]  [No Email]
F-I-T
09-07-2012 05:55:32
184.6.240.123
Re: JD 60 Governer Surging? in reply to NoDakInMN, 09-06-2012 22:21:13
Yes, that will definately cause the problem you are experiencing. The half hole short is used to pull slightly against the leaf spring, which pulls slightly on the governor internal mechanism, and it removes all the play and clearances between the sliding bushing, weights and fork. Too much tension and you can get abrupt speed changes, too loose and the governor can't respond crisply, so it lags that engine speed, so it hunts.
  [Reply]  [No Email]
Fred from MO
09-06-2012 12:08:58
69.55.155.226
I agree with what Frank said. Especially if you replaced the head and the manifold. Your old head and or manifold or new head and manifold could be or could have been milled making the distance from your carburator to the governor arm longer or shorter than your original head and manifold. If you get the rod between the governor out of adjustment, you will get the reving up and down of the engine like you are describing. Dont ask me how I know!! LOL!! BTDT!! I actually replaced a lot on my 60 when rebuilding it last winter and somehow put the rod between the carb and the governor on upside down!! ( A "DUH! Moment" for sure,) but even the simplist things can happen to a guy now and then. Good luck!!!!!!!!!!!!!!!!!!
  [Reply]  [No Email]
F-I-T
09-05-2012 20:35:16
184.6.240.123
Check that the throttle rod is one half hole short with the throttle and carb at WOT positions.
  [Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
