Topic: pto wont disengage on my john deere HELP
[Return to Forum]
| Author |
[Modern View]
| Justin SE IOWA
09-01-2012 18:26:18
166.182.3.154
I have a 1990 john deere 2995 tractor. The PTO wont disengage at all. The shaft turns weather the PTO handle is up or down even under a load from my haybine. When I got the tractor the low side of the torque amplifier slipped and I was told to always use the high side. Now its slipping also every once in a while but not all the time. When it slips I also loose power steering. I am thinking its starving for oil but the oil level is full with new hyguard oil. Yes I have read the manual but it dont state any trouble shooting. Does it sound like all my problems are related or do you think the PTO and high/low problems are separate? |
| buickanddeere
09-03-2012 13:24:33
173.241.101.74
Re: pto wont disengage on my john deere HELP in reply to Justin SE IOWA, 09-01-2012 18:26:18
| Too late now. As stated on another post.When you kept operating the tractor with a known fault. Which was the high-low clutch pack bleeding off transmission oil pressure. The pto clutch oil pressure was also reduced. The pto clutch slipped until heat warped and welded the clutch together. If you had put the tractor in the shop the 1st day the high low slipped and measured transmission pressures with a gauge. The tractor would be repaired today for a couple of grand $ tops. Now because you just couldn't stop. The tractor may well cost more to repair than going out and purchasing a replacement tractor. Please don't use the words "TA" on a JD forum and infer a JD has a TA. I read the TA statement to my family. And now the wife makes me sleep on the couch, my daughter is on extended sleep over at a friends place. The boys are too embarrassed to be seen with me. And the dog refuses to come when I call him. |
| chummy
09-03-2012 12:19:58
166.182.3.247
| We had a 44440 that the pto wouldn"t work and when the tractor strated the pto was on, when the tractor was off it would turn. We slip the tractor and found that the clutch was gone and all of the diskes were wruped badly, the clutch did not slip either |
| David S.
09-02-2012 04:49:00
68.98.247.117
| You should take some hydraulic pressure readings from the ports on the transmission shift cover, to determine if you have hydraulic leaks or pump problems. |
| Tx Jim
09-02-2012 04:11:35
67.142.163.25
Re: pto wont disengage on my john deere HELP in reply to MikeinKy, 09-01-2012 18:26:18
| open station or SGB?? Possibility of loose controls or faulty control valve. More likely warped pto plates dragging. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
