| John Deere Tractors Discussion Forum |
Topic: Bush hogging with a 4010
[Return to Forum]
| Author |
[Modern View]
| BobinIL
08-21-2012 07:22:09
128.174.125.78
I have a nice 4010 diesel that I am planning to use as a chore tractor. I know that the PTO stub shaft is not the greatest setup. How much stress will running a 7ft bush hog on this unit be? What about a 10ft rigid or 15ft bat wing? I intend to use only the 540 shaft. |
| Roger in Iowa
08-21-2012 12:24:33
166.182.3.33
Re: Bush hogging with a 4010 in reply to BobinIL, 08-21-2012 07:22:09
| I would not use a 15' and probably not a 10' on 540 because of torque and shock loads. |
| BobinIL
08-22-2012 07:49:23
128.174.125.78
Re: Bush hogging with a 4010 in reply to Roger in Iowa, 08-21-2012 12:24:33
| Maybe a 10' with a slip clutch?? |
| Tim S
08-22-2012 08:20:45
75.60.206.128
Re: Bush hogging with a 4010 in reply to BobinIL, 08-22-2012 07:49:23
| It won't be much difference to the tractor, but when you put a 15' with a 540 shaft on it behind a 4440 size tractor you have trouble keeping the mower drive line together,,the 1,000 RPM system absorbs the power better. That is one of the reasons for 1,000 RPM only in larger HP tractors. |
| Tx Jim
08-21-2012 09:25:18
67.142.163.20
Re: Bush hogging with a 4010 in reply to mjbrown, 08-21-2012 07:22:09
| I agree with what Tim stated 100% !!!!!!! |
| Tim S
08-21-2012 08:27:49
75.60.206.128
| It"s really not what you run on the PTO,,it"s keeping the stub shaft "tight",,To start out on the right track I would replace the 4 3/8" cap screws with new grade 8 bolts with a dab of loc-tite on them,,and maybe even go with new dowel pins too, when this stub shaft works loose it lets the shift pin work in and out damaging the cross pin inside, keeping the slip in the PTO shaft on the implement lubed up good helps too, as you go through the field the movement of the shaft going in and out will create "push & pull" on the stub shaft as well as the u-joints,all these things work against the 4 3/8" cap screws. |
| David G
08-21-2012 18:50:37
64.134.172.200
Re: Bush hogging with a 4010 in reply to Tim S, 08-21-2012 08:27:49
| Is this an issue on 4020 also? |
| Tim S
08-21-2012 19:00:44
75.60.206.128
Re: Bush hogging with a 4010 in reply to David G, 08-21-2012 18:50:37
| No the stub shaft problem was corrected on the 4020 |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
