| John Deere Tractors Discussion Forum |
Topic: LUC engine not getting gas to cylinders
[Return to Forum]
| Author |
[Modern View]
| Scott H.
08-19-2012 18:02:36
50.82.63.181
I've just gotten the timing and ignition issues all straightened out on my LUC power unit, but now its not drawing gas up into the cylinders. This engine has been sitting for years but looks to be in good condition. I've got a good flow of gas to the carb bowl but after cranking and cranking I'm not getting any gas drawn up to the cylinders. I put my thumb over the plug holes and seems to have compression. Would a slightly stuck valve cause the fuel to not be sucked up? Would it help if I belted the engine to a tractor belt pulley to turn it over faster? |
| Mike M
08-20-2012 05:58:26
24.140.0.120
Re: LUC engine not getting gas to cylinders in reply to Scott H., 08-19-2012 18:02:36
| My LA tractor has that problem if it sits a long time. Gas will drip out the carb. weep hole but not make it up to the cylinders. Last time I had to pull out the spark plugs a put a little in the cyl. after it gets going it is fine and even restarts days later ok. I think maybe the rings get dry and don't seal it off good ? |
| shadetreegarage
08-20-2012 05:39:15
98.21.202.20
| I would say your problem is in the carb. The M-S carb on the L-series is very hard to clean properly, especially the tiny passage at the bottom of the main passage. Get a drawing of this carb and clean it properly. Soaking it in cleaner usually won't do the job; it has to be mechanically cleaned using the proper drill bits. If you don't feel competent to do the job, give it to a pro. |
| Fixerupper
08-19-2012 19:07:28
100.42.82.164
| If you can hold the compression back with your finger while someone else cranks, the combustion chambers might not be sealed up enough to create enough suction to draw the fuel into the cylinders. Had that very same situation with a VAC Case. Everything checked out OK on that thing except for the compression which was pretty darned low. Finally gave up on starting it because it just didn't have enough lung capacity left to draw the fuel into the cylinders. Jim |
| Scott H.
08-19-2012 18:17:10
50.82.63.181
| After cranking the engine for a short while I decided to pull the rubber air cleaner hose off of the carb and when I pulled it back there was a decent amount of gas that poured out of the hose. Should I assume that theres a plugged passage in the carb then? |
| husker44a
08-19-2012 18:10:22
63.172.255.242
| Is the carb clean ? Did you clean all passages with a wire or drill bit ? A stuck valve could cause some problems but I don't think it would cause it not to suck gas into the cylinder. It would be low on compression in that cylinder if stuck open. I would also remove valve cover to varify that all valves are working properly. I have even dumped a quart of oil over the valves of an engine thats been sitting for a long time as your LUC engine as..Good Luck. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
