| John Deere Tractors Discussion Forum |
Topic: 4430 hydraulics
[Return to Forum]
| Author |
[Modern View]
| cooop
08-19-2012 10:13:26
74.206.44.182
I acquired a 4430 with known hydraulic issues. I have been trying to move it but the loader is on the ground and it will not raise. I have tried the hydraulic lever in all different positions. The clutch slips and the two speed in the quad range doesn't work. Every now and then if I press the brakes I can get something from them. The PTO engages every time I turn it on but it probably would slip if it was under a load. It doesn't make a difference if the PTO is on or off. It also doesn't steer at all. If it helps, this tractor has a JD loader on it that has 1 hose connecting to the back couplers and the return hose connects to a round protruding object below the deck on the starter side of the tractor. Does anyone have any suggestions as to what is wrong with this 4430? Thanks to all in advance. |
[Reply] [No Email] | |
| Tim S
08-19-2012 13:30:57
75.60.206.128
Re: 4430 hydraulics in reply to cooop, 08-19-2012 10:13:26
| Remove the top link mounting, then remove the plug hiding under it, reach in with pliers and "try" to pull the trans pump drive shaft out, my guess is you won"t be able to,,me believing this 4430 to be a Quad range, I thinking the pump has failed twisting the shaft off.... |
| cooop
08-19-2012 15:52:15
74.206.44.182
Re: 4430 hydraulics in reply to Tim S, 08-19-2012 13:30:57
| If the shaft is twisted off, would it have a pto that engages or brakes that sometimes work? |
| Tim S
08-19-2012 16:30:00
75.60.206.128
Re: 4430 hydraulics in reply to cooop, 08-19-2012 15:52:15
| Possibly from clutch drag, it may not be twisted clear off but the shaft could be rounded letting the pump work just a bit,,but it sounds like trans pump failure, it is a Quad range correct.. |
| cooop
08-19-2012 16:44:35
74.206.44.182
Re: 4430 hydraulics in reply to Tim S, 08-19-2012 16:30:00
| Yes, it is a quad range. |
| Tx Jim
08-19-2012 11:09:29
67.142.163.22
Re: 4430 hydraulics in reply to bob15, 08-19-2012 10:13:26
| First thing is to do is change hyd filter(AR75603),clean sump screen & check traction & pto clutch pressures on LH side to the rear of battery. Loader will not operate unless scv lever is moved the correct direction and then ind lever activated and frt pump is putting out 1700+ psi. You could also remove center link bracket and plug,then pull trans hex drive shaft out and check for wear in trans pump drive area. |
| Tx Jim
08-19-2012 11:00:25
67.142.163.22
| Quoting Removed, click Modern View to see
b&d
A quad-range trans has one rear hyd filter and a powershift has two rear hyd filters. |
| buickanddeere
08-19-2012 15:31:03
209.240.120.143
Re: 4430 hydraulics in reply to Tx Jim, 08-19-2012 11:00:25
| Just making certain what we were dealing with. It would do no harm either to install a T in the high pressure line and avoid the SCV connection. A complete flush of the hydraulic oil from tractor and loader would not hurt either. Who knows what all has been dumped and accumulated in there over the past 37+ years. The trans oil pump will be at least "tired" . |
| buickanddeere
08-19-2012 10:47:38
209.240.120.143
| | Loader oil is probably returning to a ported filter cover part # T31170. INCREASED OIL FILTRATION KIT (QUAD-RANGE AND SYNCRO-RANGE) pn AR85271 TRANSMISSION OIL PUMP (INCREASED CAPACITY) (QUAD-RANGE AND SYNCRO-RANGE) pn RE228724 Transmission Up-Time Kit PN RE213657 R50825 trans oil pump drive SHAFT 1-800-522-7448 to obtain an Operator's Manual to locate and identify item and areas that require service. Is there one or two oil filters on the transmission? |
| cooop
08-19-2012 10:58:50
74.206.44.182
Re: 4430 hydraulics in reply to buickanddeere, 08-19-2012 10:47:38
| You are right. The oil is returning to a ported filter cover.
This post was edited by cooop at 11:02:23 08/19/12. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
