| Author |
[Modern View]
| FarmerZeb
08-12-2012 21:06:01
76.92.176.221
so i finally tore into the tranny on the 2010 to fix the loss of high range gears. got torn down and the only thing that appeared worn was the high range synchro drum. i replaced it and put the whole mess back together (along with rebuilding the shift quadrant). Now it will go into high range but it won't stay there for more than 20 feet.
below is a picture of the top shaft. would like any thought if there are additional parts to replace.
thanks,
paul
This post was edited by FarmerZeb at 21:43:39 08/12/12. |
| Tech 7
08-14-2012 06:51:37
206.47.90.66
Re: synchro range frustration in reply to FarmerZeb, 08-12-2012 21:06:01
| Yes Tim I agree and would buy one if I had the chance, That one that I fought with left a bad taste in my mouth for a while but it wasn't her fault!, Bob |
| Tim S
08-14-2012 08:34:56
68.75.17.142
Re: synchro range frustration in reply to Tech 7, 08-14-2012 06:51:37
| Not me , they are a nite mare...in the old days they drove me crazy,, |
| Tx Jim
08-14-2012 04:41:38
67.142.163.22
Re: synchro range frustration in reply to Ralph Bauer, 08-12-2012 21:06:01
| FarmerZeb
Another thing to check is how worn the inside of the shifter fork is where it encloses the syncronizer. If worn too wide it can let the syncronizer separate causing shifting problems. |
| Tech 7
08-13-2012 15:43:58
76.64.213.54
| Was into a 2510 a number of years back for the top shaft. I couldn't keep that beggar working...I had installed a top shaft kit from Deere which amongst other parts included the shifter assembly that sits over the syncro drum. I got to the point that I could split that tractor in a half hour (funny how you work faster when mad). Finally discovered that the shifter had been machined wrong and wouldnt "throw" that drum far enough. Long story short I would have a look at the shifter parts. I had always admired the 2510. It has been 15 years since I had that problem and can still hear tha awful sound of it coming out of gear whenever I see one. I would still buy one but only after a real thorough test drive, Bob |
| Tim S
08-13-2012 19:44:42
68.75.17.142
Re: synchro range frustration in reply to Tech 7, 08-13-2012 15:43:58
| Tech 7, I just split a "very Nice" 2510D for a clutch, it is the first time it has been apart, nice little tractor... |
| Tx Jim
08-13-2012 13:42:52
67.142.163.23
Re: synchro range frustration in reply to buickanddeere, 08-12-2012 21:06:01
| Quoting Removed, click Modern View to see
I agree with what Cliff stated also. I agree that 2010's trans are different from from all the remaining JD syncro-range trans. |
| Tx Jim
08-13-2012 12:35:00
67.142.163.25
Re: synchro range frustration in reply to Tim S, 08-12-2012 21:06:01
| Parts key #11 is reverse shift collar,parts key # 20 is low & high range shift collar on a 4020 < SN 200.999
| Tim S
08-13-2012 13:14:54
68.75.17.142
Re: synchro range frustration in reply to Tx Jim, 08-13-2012 12:35:00
| Yes Jim, that's the line of thought I was on,, but Cliff says the 2010 is different,,I'm going with Cliff's statement,,and I hope I never have a 2010 apart again to prove it :) |
| Tx Jim
08-13-2012 05:50:21
67.142.163.20
Re: synchro range frustration in reply to swood043, 08-12-2012 21:06:01
| FarmerZeb
I was thinking that the double drum syncro was low & reverse also and the disassembled syncro was high range. But Tim has had hands on on syncro-range trans lately and I haven't in a long time. |
| Cliff Nelson
08-13-2012 10:03:01
96.60.120.179
Re: synchro range frustration in reply to Tx Jim, 08-13-2012 05:50:21
| On the 2010 it is low and reverse together and high to the rear as originally pictured. On 3010 on up to I think 55 series it is high/low together with reverse separate. That said look close at the collar splines (#31) for wear. Also too much end play on the gear. Does it jump completely out of gear or does it slip and grind? |
| Tim S
08-13-2012 11:06:11
68.75.17.142
Re: synchro range frustration in reply to Cliff Nelson, 08-13-2012 10:03:01
| I'll go with you on this Cliff,,I know 2010's are a bit different. I have been up to my neck in top shaft re-builds this summer,,but "No" 2010's .... |
| FarmerZeb
08-13-2012 11:00:18
76.92.176.221
| | #31 did not appear to be worn at all. it will move about 20feet grind for 5 seconds or less and be completely out of gear. -paul |
| Tx Jim
08-13-2012 04:13:20
67.142.163.20
Re: synchro range frustration in reply to Art S., 08-12-2012 21:06:01
| Parts key #33 is high range retainer. |
| Tx Jim
08-13-2012 03:59:03
67.142.163.20
Re: synchro range frustration in reply to chrisfromsolitude, 08-12-2012 21:06:01
| Did you inspect the rollers(parts key #11) and the grooves that rollers operate in the shifter(parts key #18)?? Also did you check shifter dent spring and detent(parts key #10 or 26 depending on SN)?? Did you check the 4 balls & springs(parts keys 34 &35 in next photo) in the high range retainer???
I don't know why this photo won't appear.
[img]http://ytforums.ytmag.com/photos/10010.jpg[/img]
This post was edited by Tx Jim at 05:46:26 08/13/12 5 times. |
| Tim S
08-13-2012 04:08:21
68.75.17.142
Re: synchro range frustration in reply to Tx Jim, 08-13-2012 03:59:03
| The collar and drum that you seem to be pointing out in the picture is for reverse.....you should go through the hi/low drums and collar also.... |
| FarmerZeb
08-13-2012 05:34:41
76.92.176.221
Re: synchro range frustration in reply to Tim S, 08-13-2012 04:08:21
| | thanks for the response, i did not take the retainer / blocker off (parts key 33) and inspect it. it seemed to function just fine but it apparently cannot hold the high range in gear. id did inspect the cam, forks, and detent spring and they appeared ok......however this is my first synchro range tranny so i have no reference point as to what too much wear is. Tim S. if you could please clarify your post. The synchro drum that is off the shaft is listed as the high range syncrho in both my svc manual and jd parts.com. The forward 2 synchros control low range and reverse....but that is how i read the manual.... like i said this is my first synchro rebuild. many thanks,
paul |
| Tim S
08-13-2012 11:02:54
68.75.17.142
Re: synchro range frustration in reply to FarmerZeb, 08-13-2012 05:34:41
| I will double check on the 2010 parts,,But on all other sychro's the reverse is at the rear of the shaft on it's own,,fortunately I have not had a 2010 trans down for a while,,but I'm still thinking I am right about this... |
| FarmerZeb
08-13-2012 18:42:29
76.92.176.221
Re: synchro range frustration in reply to Tim S, 08-13-2012 11:02:54
|  this should help |
| Tim S
08-13-2012 19:46:36
68.75.17.142
Re: synchro range frustration in reply to FarmerZeb, 08-13-2012 18:42:29
| FarmerZeb
08-13-2012 19:58:01
76.92.176.221
Re: synchro range frustration in reply to Tim S, 08-13-2012 19:46:36
| | i appreciate all the replies i will have to back burner this for a few weeks as i have another tractor that needs to go into the shop for a few seals and a paint job before the weather get cold but i will split this thing again in a month or so (grrrrrrrrrrrrrrr) will post back with more pics of the shifter and cams when i do -paul |
