Yesterday's Tractor Co. Affordable Parts, Just in Time
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: powershift tech support
[Return to Forum]
smittyjd
08-12-2012 09:05:59
98.21.77.77
is there any one, or who is the best company to call for beefing up a powershift. i have one i farm with and also pull with. i want to make sure that 7th gear will hold up. thanks for the help.
for advice, i'll let you know, that i have double sprung the torsional dampner with 4840 outer springs and 4630 inner springs. i also put a 1/2 washer in the cup. my system pressure is 195. can i go more? thanks for any help.
[Reply]   [No Email]
larryanderson
08-13-2012 03:44:37
75.105.32.39
Re: powershift tech support in reply to smittyjd, 08-12-2012 09:05:59
It would take more than 300 H.P. to be able to pull a normal sled in eighth.The jump from 7th to eighth would be about 30% which at 3000 RPMs would be about 25MPH+.I know the guys with a lot of power have wheel speed of 40+ but usually have 750+ H.P.300 H.P. is pretty good for a basically stock unit. I havent seen any powershifts in the few pulls I help with.Even though we have JDs the Red ones are hard to beat especially if you are trying to keep the cost down.Big JD H.P.is expensive.I know a guy that made some over a million dollars pulling that started with around two.Just Kidding.
  [Reply]  [No Email]
smittyjd
08-13-2012 04:16:00
98.21.71.136
Re: powershift tech support in reply to larryanderson, 08-13-2012 03:44:37
i didn't know what would happen. just a thought. in the 10500 class i know that i had almost to much gear in 7th. its not to much of a big deal. i know its easier to through a truck engine in a 1066 and go, but i'm a deere man. i have noticed 2 things since i started playing with this tractor. my tractor pulls best between 13,000-16000. i also noticed that those reds ones are a little more down to earth at that weight also. its all in fun. some day i will probably build a hot farm j/d using the quad range tranny where i can pull at 9-10000 lbs. but for now, i'll keep playing with my farm tractor that has a cab on it.
  [Reply]  [No Email]
wisbaker
08-12-2012 18:56:02
207.118.159.66
Remember Murphy's 7th law, if you mess with anything long enough you will indeed break it.
  [Reply]  [No Email]
Tim S
08-12-2012 16:17:12
68.75.17.142
The 8spd. power shift is not a good choice to pull with...they are good with the rated HP, or a bit more, but won"t deal with high HP...
  [Reply]  [No Email]
smittyjd
08-12-2012 16:39:07
98.21.77.77
Re: powershift tech support in reply to Tim S, 08-12-2012 16:17:12
im not looking for huge h.p. i like my p.s enough that i am not getting rid of it to go pulling. i go to about 3 or 4 a year at local fairs. i guess if i want to get into pulling i would probably look for a quad range.
  [Reply]  [No Email]
Tim S
08-12-2012 18:02:12
68.75.17.142
Re: powershift tech support in reply to smittyjd, 08-12-2012 16:39:07
I see what your doing now,,I thought you may be setting up for 500 and up HP.
  [Reply]  [No Email]
MSM
08-12-2012 14:33:09
75.243.37.132
You have plenty enough lube pressure, and with the disconnect clutch setup you won't get any slip there. Seventh gear should be fine, but remember you are shifting 3 clutch/brake packs at the same time,which gives the "delay". If you are way up in the HP department the input shaft will likely become the "shear pin"
  [Reply]  [No Email]
smittyjd
08-12-2012 16:09:27
98.21.77.77
Re: powershift tech support in reply to MSM, 08-12-2012 14:33:09
i am around 300 h.p. all i did to the 404 was have my intector pump turned up and govenor weights changed. i was told that by drilling out the orfice found where the accumulators are, that would make my shift faster. right now i am pulling 13,500 in 7th gear. starting out in 5th. it shifts really nice. i am just looking for any way i can make that unit top notch. i just rebiult the whole thing and want to protect it. like i said, i can through on my stock pump and farm with it. thanks for the reassuance though. do you think it would hold in 8th gear. i have mine down to 10,000 and would like to try it.
  [Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
