Yesterday's Tractor Co. Affordable Parts, Just in Time
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Wico XB Distributor - resistor why?
[Return to Forum]
bjh2915
08-10-2012 13:42:41
107.8.185.166
What is the purpose of the coil of wire which is in between 6Volts that goes to the on/off switch and Red lead up to the coil low voltage side. I am assuming that this is the resistor that is discussed with XB Distributor.
[Reply]   [No Email]
teddy52food
08-10-2012 19:09:31
184.94.175.179
Re: Wico XB Distributor - resistor why? in reply to bjh2915, 08-10-2012 13:42:41
Just guessing, but that coil looks just like those found in a magneto. I dought if a mag developes the wattage that a 6 volt battery would. I am sure if you wired it up without the resistor it would give a good hot spark but wouldn't last long.
  [Reply]  [No Email]
Kurt_JDB
08-10-2012 17:43:22
74.167.224.109
And to add to what John T and Buck eye al said, When the XB was put on a 12 v. tractor ( the A for example) an extra EXTERNAL resistor was added at the power stud. This was absolutely notorious for not working right, and burning out coils. The XB (according to Glenn) was really designed for 6 v. systems, and use on 12V systems with the extra resistor was sort of a hack.
Kurt
  [Reply]  [No Email]
F-I-T
08-10-2012 19:13:39
184.6.240.123
Re: Wico XB Distributor - resistor why? in reply to Kurt_JDB, 08-10-2012 17:43:22
How can a hard, wire resistor fail to a lesser resistance? If they fail, it's an open. Otherwise, physics as I know it, has been rewritten.
Thousands were run on Model "A"s with no problem. The PROBLEM was when farmers broke a hook lead and kept shortening them,and got less and less resistance, or, they deleted the resistor entirely at the first ignition switch change. An XB will work fine, if you keep everything true in the circuit. I prefer Delco's, but ran a Wico XB for the first 40 years on our "A". 40 years is tough beef over.
  [Reply]  [No Email]
John T
08-10-2012 18:13:33
216.249.82.117
Yeppers, they (XB's) were used on some early B's, which, were indeed 6 volts.......The literature from Glen you sent shows an X7350 inline resistor for use on 12 volt.
John T
  [Reply]  [No Email]
John T
08-10-2012 16:38:52
216.249.82.117
Al has ya covered, I think the Part Number (From Glen and Kurt) is X6822 for the resistor assembly.......
John T
  [Reply]  [No Email]
buck eye al
08-10-2012 15:25:02
168.251.194.11
Short answer: The resistor is there to limit the current through the main coil.
The main coil of the XB distributor is designed to work with a rather low voltage. Well less than even 6 volts. Withiout this resistor which can be tailored for whatever system voltage a tractor has it will pass too much current, overheat and burn out the coil. The resistor is therefore added to reduce the current passing through the main coil to a safe (for the coil) level.
Remember, all electrical devices are manufactured with one common ingredient. They all have at least some smoke in them & once you let enough of that factory installed smoke out of them they're no longer any good! That resistor helps keep the factory installed smoke in the coil!
  [Reply]  [No Email]
bjh2915
08-11-2012 05:55:33
107.8.185.166
Re: Wico XB Distributor - resistor why? in reply to buck eye al, 08-10-2012 15:25:02
Thanks for all the inputs. This resistor is a continuous piece of wire, wound up to look like a coil. I can see where it could easily be shortened because it broke and little by little it got shorter with less resistance. Love the smoke story!
  [Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
