| Author |
[Modern View]
| bjh2915
08-07-2012 13:12:02
107.8.185.166
How do I know whether I would use a short or long Lug?? Where is this lug located? ConfusedWICO SPEC XH1042 (SHORT LUG) MAGNETO WICO SPEC XH477B (LONG LUG) MAGNETO |
| JDG
08-07-2012 18:53:06
71.62.30.30
Re: WICO Mags long lug short lug??? in reply to bjh2915, 08-07-2012 13:12:02
| Bill I think you need to get a partsbook. All your questions will be answered and help you to understand better. |
| rusty wheel
08-07-2012 14:34:35
75.180.23.218
| You should be able to measure from the face of the governor to the drive lug and determine what you need. I think I have some adapters I made to change a short lug to a long lug. |
| john deere haverstor guy
08-07-2012 13:59:58
66.82.20.123
| on the end of the mag were it connects to the governor. You got flat ears that go in the slot on the governor and there either long or short. |
| Will P
08-07-2012 13:57:58
98.100.179.46
| Depends on what year the tractor is. It is the drive lug. |
| bjh2915
08-07-2012 14:08:21
107.8.185.166
Re: WICO Mags long lug short lug??? in reply to Will P, 08-07-2012 13:57:58
| Ok, that is what I thought it might be. I have a WICO XB Distributor and I am thinking about going to a Mag or Delco distributor. So, my question then is.... which Mag do I get... Short or long? |
| Mark-Ia
08-07-2012 14:34:12
67.55.246.70
Re: WICO Mags long lug short lug??? in reply to bjh2915, 08-07-2012 14:08:21
| Short lug. The long lug was used on the unstyled tractors. |
| bjh2915
08-07-2012 14:58:04
107.8.185.166
Re: WICO Mags long lug short lug??? in reply to Mark-Ia, 08-07-2012 14:34:12
| bjh2915
08-07-2012 16:17:29
107.8.185.166
Re: WICO Mags long lug short lug??? in reply to bjh2915, 08-07-2012 14:58:04
| The WICO XB that I have now has something that looks like the blade from a blender accept that it is rectangular and not sharp. I'm going to measure the distance tomorrow but from all said.... it must be a short lug Mag that I would use. I'm wondering what that Delco distributor looks like now? |
| teddy52food
08-07-2012 19:41:08
184.94.175.179
Re: WICO Mags long lug short lug??? in reply to bjh2915, 08-07-2012 16:17:29
| I have a couple of those here too and they are short lug. |
| Kurt_JDB
08-07-2012 17:25:29
74.167.224.109
| | Here is a link to a Delco for a two cylinder Deere at Brillman. Enjoy! Kurt |
| bjh2915
08-07-2012 17:47:26
107.8.185.166
Re: WICO Mags long lug short lug??? in reply to Kurt_JDB, 08-07-2012 17:25:29
| | Ah! yes. I found this place and have sent them a couple of questions. Since the WICO XB and the Delco have differnt bases (the WICO has bolted top and bottom connections the Delco is round with no bolted connections????? There has to be something to clamp the Delco to the Deere govenor. Bill |
| Kurt_JDB
08-07-2012 20:37:05
74.167.224.109
Re: WICO Mags long lug short lug??? in reply to bjh2915, 08-07-2012 17:47:26
| | Bill, The round base fits right into the the governor. It is round so you can turn it to adjust it. There are two small clamps that are mounted on the governor in the same two points that hold the mag or XB. The Parts book for the "50" tractor shows the Delco distributor. It was original equipment from Deere. If you buy one, be sure to get the clamps. The Delco was also available from Deere as a replacement for the XB. Kurt |
| bjh2915
08-08-2012 07:08:52
107.8.185.166
Re: WICO Mags long lug short lug??? in reply to Kurt_JDB, 08-07-2012 20:37:05
| Thanks once again. That makes sense about the clamps. So, if I go the Delco way I need a 6 volt coil to go with the distributor and a way to mount both and I should be good to go. |
