| John Deere Tractors Discussion Forum |
Topic: Three Way Valve
[Return to Forum]
| Author |
[Modern View]
| jerryinga
08-06-2012 13:45:14
24.181.64.20
I am finishing up my restoration on a 1939 H and I have a fuel leak Problem #1 The 3W valve will not cut the fuel off completely It has a slow leak into the carb and also backs into the small tank. I have the nut tight and new felt packing. Problem #2 The Gland Fittings on the fuel line continue to leak at the 3W valve Very little maybe one drop every two hours but enough to mess up the new paint. Can I put some type of sealer on the face of the Gland? I have thread compound on the threads Thanks Jerrel |
[Reply] [No Email] | |
| F-I-T
08-07-2012 06:37:41
184.6.240.123
Re: Three Way Valve in reply to jerryinga, 08-06-2012 13:45:14
| Quoting Removed, click Modern View to see
Problem #1:
Best way I have found is to lap them, and if that is not enough, I cut two notches for o-rings. Did that to my first all-fuel, a '42 "H" back around '78. Stops leaks and drips dead. I open the carburetor drain, catch the fuel, dump it in the tank as the engine dies, then let the drain open until the next time.
Problem #2:
If the glands and nuts have been strained hard and deformed over the years, I build new lines out of steel brake line and silver (or high lead solder if you have the steel really really clean)new glands on the ends, available from Roberts Carb. Long way to fix it, but it's factory new. |
| Resting Relics 1
08-07-2012 05:32:46
24.151.93.68
| Hey Jerry, I've gotta agree with 41 Frank. The best way to stop the seepage is to use a good screw in type fuel bowl which positively shuts off the fuel. The quarter turn style simply leak by. Then run the tractor out of fuel as intended. With the fuel shut off this way the three way can be tightened up so it won't leak and forget running it on the small tank. I put a little diesel fuel in mine to keep them from rusting. Good Luck! John |
| Morris Krodle
08-06-2012 20:00:33
71.96.132.174
| The late Pat Browning has a fix for the 3-way valve, got to JDHPubs.com. He has some great articles for all JD "H". |
| teddy52food
08-06-2012 19:14:05
184.94.175.179
| There is a product that I use from Dow Corning called Molykote 111. It is a non-hardening silicone that resists gasoline. Works good to seal the bulb gasket even using the old gasket. Helps to lube & seal gas line fittings too. McMaster Carr has it. |
| John T
08-06-2012 15:13:22
216.249.82.117
| | On that valve perhaps some valve grind compound and lap lap lap it down. Once I get one so it dont leak I wouldnt ever dream of turning it as I dont ever use the little tank anyway. John T |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
