Yesterday's Tractor Co. Same-Day Parts Shipping Available
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: JD 730D Clutch
[Return to Forum]
peterverity
08-02-2012 21:04:19
198.254.166.50
The drive pin came loose last year and I discovered it was broken and the hole it fits into in the pulley had been damaged. The tractor hadn't been working hard and I believe this damage must have occurred with the previous owner. I welded up the pulley hole and ground it out carefully to get a tight fit with the new pin. Well, the pin came loose again yesterday, again, with not much load. Perhaps the pin is an interference fit on the pulley (has to be hammered in)? Has any one successfully made this repair without going to a machine shop? Thanks. Peter
[Reply]   [No Email]
F-I-T
08-03-2012 09:37:53
184.6.240.123
Re: JD 730D Clutch in reply to peterverity, 08-02-2012 21:04:19
...Perhaps the pin is an interference fit on the pulley (has to be hammered in)? ...
Yes, it is a press fit into the pulley boss.
... Has any one successfully made this repair without going to a machine shop?...
Well, that depends on how steady you are and the quality of your drill press, or preferably, a small mill/drill unit. On some pulleys, there are three equal bosses, so if you have a bad hole in the original boss, you can redrill on one of the other yet to be used boss lobes. If you only have one boss, you either weld it shut so that you can redrill, or move up to an oversized pin. That way, you can redrill the operating sleeve pin hole to that new pin size, or use a bushing, or weld it shut and go with the standard pin, BUT, you have to be very careful to locate those two holes dead on top of one another, so that the sleeve slides in and out along that pin without binding. I use a rod like Muggy Weld for the filling of thew hole, since you need machinability. Tig might work, too.
Not sure if or who sells the oversized pin these days, if at all, but the original I think was a 7/16" x 2 1/4" dowel pin, so you probably have room to go to 1/2". OR, you could have a 1/2" pin ground down to 7/16" to match a standard hole in the sleeve, and punch the new hole in your pulley to 1/2", but it must be a good press fit into that pulley blind hole.
This is the weaest link in the drive, so you need to get this fixed right, and it will work fine for years again.
Or...you can look for a decent used pulley.
  [Reply]  [No Email]
Peter Verity
08-04-2012 08:49:48
198.254.166.50
Re: JD 730D Clutch in reply to F-I-T, 08-03-2012 09:37:53
Many thanks F-I-T for your detailed and comprehensive reply.
Based on your comments I now think I'll take it to a m/c shop and
get it done properly.
  [Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
