| John Deere Tractors Discussion Forum |
Topic: John Deere H
[Return to Forum]
| Author |
[Modern View]
| MTC
08-01-2012 13:42:59
207.190.96.157
just bought a H which is smoking.Starts with white smoke and then it is blue.Tore the motor apart and there is no ridge on cylinder and the rings look good.Do not see any cracks any where.Maybe valve guides? Ideas? Thanks |
| rusty wheel
08-02-2012 10:31:01
75.180.23.218
Re: John Deere H in reply to MTC, 08-01-2012 13:42:59
| Those engines run on fairly low oil pressure. If the oil pressure is too high, it could force oil by the rings causing it to smoke. I think white smoke would be another problem altogether. Might want to take the antifreeze out of it and run plain water until you find the cause of the white smoke. Just a thought. |
| dan_41jdh
08-01-2012 14:51:23
24.149.8.64
| | As Bob Harvey mentioned, white smoke is usually a sign of water, but blue smoke is definitely from oil. It"s possible that your valve guides are worn; they"re easily checked now that you"ve opened and disassembled the engine. Valve guides are supposed to be 0.377/0.376" diameter, and valve stems are to be 0.372/0.371" diameter, for max/min clearances of 0.004 to 0.006 inches. If there is significantly more clearance, it is possible the intakes could be sucking oil and causing smoke. However, smoking from loose valve guides usually lessens under load and increases at idle (when the manifold vacuum increases). Bad rings will usually cause smoke more under load than at idle. Have you checked your oil rings (assembled correctly if of the 3-piece configuration) and that the holes in the oil ring groove of the piston are not clogged with carbon? How about end clearance of the rings? Although there is no ring groove in the cylinder, is the piston clearance correct? (Did someone ream out the ring groove previously and thus left the impression that there was no ring groove for the next person to open the engine; therefore, the bore is "good"? (as-new clearance, skirt-to-cylinder is supposed to be about 0.004".) At this point, since you have the engine torn down, I'd suggest you start measuring and rebuild the engine to the proper specifications. |
| Bob Harvey
08-01-2012 14:22:14
209.91.107.235
| White smoke normally indicates coolant from ?????? |
| Ray Durham
08-01-2012 17:35:27
68.98.196.60
Re: John Deere H in reply to Bob Harvey, 08-01-2012 14:22:14
| Be thankful it was just smoking and not smoking, drinking and running around with other deeres! |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
