| John Deere Tractors Discussion Forum |
Topic: JD 620 power steering pics
[Return to Forum]
| Author |
[Modern View]
| Canadian Ken
07-29-2012 09:27:31
74.114.79.204
  Assembled the cams, shaft, spring held in place with the nut, not tightened to original tension -the wear on the cam stud/rod -when the moveable cam is turned, the corners catch on the stationary cam -slid the assembly in the sleev and rotated it with vice grip attached to non machined surface -the shaft had a distinct catch everytime rotated - will try with spring properly tensioned -my thought is that the moveable cam bore is quite loose on the rod/stud in additional to the wear groove on the stud and wear inside sleeve allows cam to tilt enough so that the corners catch while rotating -I will clean up all the surfaces -remove burrs and level out divots -ordered new dowel pins even though very little wear on present ones -and flip the rod/stud end for end to get vway from the wear groove and try rotation-- Are the corners of the moveable cam supposed to be beveled or square -bevelled due to wear? Best tool to use fine file, emery cloth, stone -? Ken |
| F-I-T
07-30-2012 06:22:58
184.6.240.123
Re: JD 620 power steering pics in reply to Canadian Ken, 07-29-2012 09:27:31
| I was thinking that maybe Ken should ink that worm cam surface with a magic marker, or layout die if he has it, then assemble it and crank it back and forth several times. Then take it apart and examine the wear pattern. My guess is that it shows up where my arrows point. He can reclaim that worm if a good Tig job is applied, but I sure would look for a replacement, and redress that one. You're right, it sure took a hard hit at the extreme left or right, whichewver it is. Surprised it didn't crack that hardened dowel. |
| F-I-T
07-29-2012 15:39:16
184.6.240.123
| The faces have to be stoned smooth. I use a high rpm air die grinder, and a 1/4" stone. The form is basically a 45* slot, slightly less than a 1/4" wide, formed to fit the 1/4" dowel pins at the end of travel. Arrows show where I would stone out for catching.
| Canadian Ken
07-29-2012 14:37:07
74.114.79.204
|   pics of the cam face on the shaft -it looks really good |
| F-I-T
07-29-2012 09:50:32
184.6.240.123
| WOW, Ken! You're looking at the wrong place! There is/was a cam face on the end of the worm, and it is broken away! That's where the other pin rides.
Unless I'm seeing it wrong. Disassemble that group and let me see the worm cam face straight on and side ways, and the same for the other cam. Those two things you are looking at above act as sort of a slip clutch to determine how much force it take to begin assist.
This post was edited by F-I-T at 09:56:19 07/29/12. |
| Canadian Ken
07-29-2012 14:31:59
74.114.79.204
Re: JD 620 power steering pics in reply to F-I-T, 07-29-2012 09:50:32
|         Sorry Frank, but it my first power steering repair -thanks for any help-I did notice the cam face broken away, but it is not broke out full depth -when i compress the spring to former length and turn the moveable cam, the cams overlap and jam -yes it is out of the sleeve, but with internal wear in the sleeve i think this is also happening causing the catching - i am showing both dowel pins as well |
| Rich Duane
07-30-2012 05:00:20
72.45.55.37
Re: JD 620 power steering pics in reply to Canadian Ken, 07-29-2012 14:31:59
| F-I-T, You are right, the end of the helix ramp should be repaired or the worm replaced. With that corner broken off you have a problem with the pin jumping over that edge and sticking there.At sometime someone really put some pressure on this worm to brake that corner off. The reason it only broke the out side is that the pin does not go all the way to the bottom of the helix slot The rounded corners are for manual operation of the steering. Rich |
| Mike M
07-30-2012 12:27:22
24.140.0.120
Re: JD 620 power steering pics in reply to Rich Duane, 07-30-2012 05:00:20
| I have seen simlar breakouts on those before. Seen a few split clear down the keyway too ! The improved design is not an improvement in that area. From new they were never profiled properly to get full contact with the pin on that one end. They only hit the corner. when I build them back up and dremal them to shape I like to keep working to get full contact. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
