Topic: 2350 vibration/chatter?
[Return to Forum]
| Author |
[Modern View]
| Kelly MT
07-28-2012 22:48:36
216.14.251.158
A friend has a JD 2350 and after about a hour of work it starts to have a vibration that does not seam to be related to the clutch or engine. It can be felt in the loader joy stick. After it cools down it's gone. Fluid levels are good. Any ideas? Thanks PK. |
[Reply] [No Email] | |
| Tx Jim
08-29-2012 03:55:22
67.142.163.21
Re: 2350 vibration/chatter? in reply to JohnS1970, 07-28-2012 22:48:36
| Quoting Removed, click Modern View to see
Sounds as if the frt hyd pump is cavitation from either lack of sufficient supply oil from trans pump or an internal high pressure hyd leak. At lot of hyd diagnoses will be required. Check hyd components with a laser thermometer for excessive heat. What types loader control valve? How long since hyd filter was changed and sump screen cleaned?? Changing filter and cleaning sump screen would be first on my diagnoses list. |
| kelly mt
08-28-2012 17:20:04
216.14.251.158
Re: 2350 vibration/chatter? in reply to Kelly MT, 07-28-2012 22:48:36
| I Finally got to check the 2350 my self and the vibration is through out the hydraulic system. The loader stutters up or down as does the three point which also moves up and down about an inch on it"s own. The loader valve lines can be seen to vibrate. I can see no oil spray or vapor through the fill hole. Any ideas? |
| 730-LP
07-31-2012 10:10:42
75.216.250.223
| Wrong oil or oil is worn out,change filter and replace with John Deere hy-guard. |
| Kelly MT
07-29-2012 16:43:14
216.14.251.158
| Thanks for the reply. I'll do the testing. Might be a few days, I'm hot and heavy into haying. Thanks, PK. |
| Tx Jim
07-29-2012 04:15:54
67.142.163.25
Re: 2350 vibration/chatter? in reply to James Howell, 07-28-2012 22:48:36
| Sounds as if it's a hyd problem. Probably main hyd pump cavitation from not having enough supply oil from trans pump or an internal high pressure hyd leak. First thing to do is with 3pt raised,engine running look inside hyd oil filler hole for spraying oil. Second check hyd stand-by pressure in rear remote plugin equipped) for 2250-2350 psi.3rd disconnect joystick valve return hose,aim in hyd filler hole or 5 gal. bucket,crank engine with JS in neutral and see if any oil shoots out hose.4th report here the tests results. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
