| Author |
[Modern View]
| sideconsole4020guy
07-26-2012 20:59:12
216.249.194.192
Does any one have a picture of a 4020 with the extra long rear axles, I want to see how far they would stick out as I am looking to find longer rear axles for mine to run axle duals and I have always like the look of extra long axles, and how long were the special dual axles?
Thanks
Zach |
| tommy_harrell
08-02-2012 20:14:24
67.142.168.144
Re: 4020 Axles in reply to sideconsole4020guy, 07-26-2012 20:59:12
| [URL=http://rides.webshots.com/photo/2674719570062421792iCahwC][/URL]
Someday I hit something with them.
Tommy |
| sideconsole4020guy
08-02-2012 20:18:46
216.249.194.192
Re: 4020 Axles in reply to tommy_harrell, 08-02-2012 20:14:24
| Those are the axles like I want they would look great with factory dual hubs out on the end |
| 4020_1966
07-31-2012 17:47:33
68.69.40.103
| 4020_1966
07-30-2012 13:23:25
166.147.104.145
| Dad's 64 has the extra long ones. they stick out a long ways and they dont have the splines for the axle mover gear to go all the way in for 30" rows. We have to pull the pin which lets the little gear pop up and then we use a bar to push the tire in the last few inches. I have the short ones on mine. I haven't really ever noticed catching the lonng axles on stuff, but then I've driven that tractor since I was a kid. I will look for a picture showing teh axles. |
| sideconsole4020guy
07-30-2012 20:23:08
216.249.194.192
Re: 4020 Axles in reply to 4020_1966, 07-30-2012 13:23:25
That would be great if you could find a picture, I know i dont really need extra long axles but i think they look cool |
| Scott 730
07-28-2012 06:40:35
75.168.161.86
Re: 4020 Axles in reply to Kansas4010, 07-26-2012 20:59:12
| Quoting Removed, click Modern View to see
Would be a lot less grief to just get a pair of spacers to put on between your hubs and duals. :D |
| sideconsole4020guy
07-28-2012 12:08:32
216.249.194.192
Re: 4020 Axles in reply to Scott 730, 07-28-2012 06:40:35
| that is true but i cant get to 30" rows with the axles i have now any way so I would like different ones, plus I am over a period of time trying to make my 4020 one with as many options as i can, kind of a goal of mine to have an all decked out all option 4020 |
| Tx Jim
07-27-2012 05:29:31
67.142.163.25
Re: 4020 Axles in reply to hayfarmer, 07-26-2012 20:59:12
Larry
If I remember correctly from my tractor hauling days from Waterloo to Texas besides the permit the axles must also be flagged to keep the DOT satisfied. |
| larryanderson
07-27-2012 04:45:03
75.107.96.58
| On the early ones we had to run 6in spacers to fit 30in rows.The 69/72 had at least 6in more axle as the spacers were not required.If you are going to use factory wedge style duals the hubs are about 6in shorter than a hub with clamps.I have seen a few that had them cut off so they dont stick out.The 30/40 had some real long axles that were almost dangerous and any axle more than what you need can be a problem.Hauling long axle tractors requires a permit.105 is not as big of problem as 110 and there are some longer yet. |
| sideconsole4020guy
07-27-2012 04:54:43
216.249.194.192
Re: 4020 Axles in reply to larryanderson, 07-27-2012 04:45:03
| My 1970 4020 has short axles and they do not have the rack cut into the axle all the way in I can get my wedge hubs on but the axle is about 2 inches short, my dads 1970 4020 has a axle that is perfect for duals and has the rack cut all the way into the axle housing so he can get on true 30in rows, thats the type of axle I want its not too long and useful |
| 4020deereboy
07-27-2012 21:31:07
205.185.95.11
Re: 4020 Axles in reply to sideconsole4020guy, 07-27-2012 04:54:43
| My hubs on my 4020 are out past the end of the axle about two inches had to run em that way in order to get two sets of wheel weights on . |
| sideconsole4020guy
07-28-2012 04:59:02
216.249.194.192
Re: 4020 Axles in reply to 4020deereboy, 07-27-2012 21:31:07
| Yeah mine have to be like that because they dont go in any farther, I am thinking of swapping axles this winter to some so I can get to 30" rows and have dual hubs on there that are in the right position for 30" rows |
| Tx Jim
07-27-2012 03:24:42
67.142.163.25
Re: 4020 Axles in reply to husker44a, 07-26-2012 20:59:12
| Long axles are a pain when one doesn't have duals on. I use my 4255 with long axles for rd baling and it will just barely squeeze through a 10 ft opening. |
| 4020deereboy
07-27-2012 01:01:27
205.185.95.11
| The parts books shows four axle lengths 33 7/8 37 1/16 41 1/16 45 5/8 |
