Yesterday's Tractor Co. Compare our Prices For Parts
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: JD A crankcase pressure
[Return to Forum]
bard
07-26-2012 05:02:10
75.88.137.40
I got a '48 or '49 A here. When I run it around the driveway only a few minutes it starts smoking out the vent, around the clutch and flywheel quite a bit and not even working the tractor hard. I did a compression test and it has about 65 pounds and holds it good on both sides. Is the engine weak enough to make it smoke this bad at that pressure or is there another issue and if so what could it be? Thanks
[Reply]   [No Email]
JDG
07-26-2012 18:52:42
71.62.30.30
 Re: JD A crankcase pressure in reply to bard, 07-26-2012 05:02:10
This may sound stupid, but I have a 44 A that was doing the same thing and I found the timing was way off. It didn't fix it 100%, but it was a 98% cure
[Reply]  [No Email]
wisbaker
07-26-2012 10:30:38
207.118.164.126
If you're really luck the rings are just gummed up and stuck, check the stuff the other guys recommended, lube it up and work her some while keeping a careful watch the oil level. Might not hurt to treat your fuel with Seafoam or Marvel Mystery Oil and see if she gets any better.
[Reply]  [No Email]
Kurt_JDB
07-26-2012 09:34:49
74.167.224.109
65 lbs sounds low to me unless you have an allfuel engine with the original low compression pistons. Sounds more like blow-by to me from tired rings and/or worn cylinder walls.
Certainly worth checking it again with another gauge and checking out the ventilator fan and tube as others have suggested.
Kurt
[Reply]  [No Email]
rla
07-26-2012 05:54:30
162.39.22.109
65 pounds with the trottle plates open or closed when Checking??
If that measurement is with the plates open
it's pretty weak. Also there is a crankcase
ventaltion pump at the rear of the fan shaft
& just ahead of the govener box. Make SURE!
it's working & Make SURE the Pipe running up
to the Carb inlet is Clean Free of Crudd.
Those are a couple things I'd Check 1st.
[Reply]  [No Email]
Resting Relics 1
07-26-2012 06:26:37
24.151.93.68
 Re: JD A crankcase pressure in reply to rla, 07-26-2012 05:54:30
Hey Bard,
If the vent pump up by the fan is original or the tractor has had a lot of use it's probably in need of repair. The springs and vains are probably broken or gummed up. Check the obvious stuff first as rla says but it's probably not that easy. Good Luck!
John
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
