Yesterday's Tractor Co. Fast, Friendly Parts Service
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Carb on A
[Return to Forum]
Farmallb
07-22-2012 10:37:40
67.142.178.21
I cant afford to buy a kit for it, $90 with shipping till my SS check next month. Im going to let a carb rebuilder outa neighboring NAPA do it as he does that. He says he hasnt built one for a JD A for a LONG time and would like it kept together when he gets it. I thought Id put it in a gal can and fill it with Chemtool to soak till I could afford to buy the kit. The Chemtool 1/2 evaporated the next day. I bought one of those cans with a lid and a screen inside. The carb wouldnt go inside it together. I cant think of anything that I could seal it in that has a mouth/lid that big. Any ideas?
[Reply]   [No Email]
dondeereb
07-23-2012 22:49:06
65.170.243.186
 Re: Carb on A in reply to Farmallb, 07-22-2012 10:37:40
these guys are giving you good advice. if the fellow you have lined up to rebuild it has never done it you probably should look elsewhere. they are right, carb cleaner is not of much use on these carbs, plus all the brass drill plugs must be removed and the passages drilled out with the proper sized drills. thats the only thing that will remove rust. to remove the brass plugs you have to heat them with a torch just till you see a slight tinge of green in the flame then remove heat immediately. set carb aside and let it cool and all plugs will come out very easy. any other way and you will twist most of them off. also be gentle with the main jet or you could break it off too. heat the bowl nut as well or you will twist it off and have a carb that is no longer of any use. after i have the plugs out i bead blast my carbs down to bare metal. then plug all openings and give it a pro paint job. you can get replacement drill plugs on this website or other two cylinder parts houses if the ones you have are damaged due to improper removal attempts.
hope this helps, good luck
[Reply]  [No Email]
dondeereb
07-23-2012 22:47:37
65.170.243.186
[Reply]  [No Email]
NoDakInMN
07-23-2012 08:34:10
76.10.68.191
Usually the problems with these carbs is not varnish, or other things that carb cleaner works on, but rust. Rust will have to be removed with properly sized aircraft drill bits. So soaking it, while it may seem a good idea, will not do much in the long run.
If your guy does not understand the need for removing rust with drill bits you might be better off to continue looking for someone who does, otherwise you are headed for disappointment.
[Reply]  [No Email]
B-maniac
07-22-2012 13:33:54
97.85.62.26
Can't blame him. He doesn't want any unnessessary rounded off srews or twisted off bowl threads to deal with. Do as he says and leave it out of the "gunk" and give it to him in one piece. Probably be less cost to you in the end. RB
[Reply]  [No Email]
greenday
07-22-2012 12:46:14
64.91.95.222
carb cleaner wont do much for cleaning the passages on this carb
[Reply]  [No Email]
Mark-Ia
07-22-2012 11:51:22
67.55.246.70
Many places have a carb kit much cheaper than $90.00. The local Tractor supply type store has them for around $25.00. Check Ebay also..
[Reply]  [No Email]
old
07-22-2012 10:52:21
209.86.226.27
Should be able to find a Walker brand kit from say an O'Reilly's for around $20 or so. As for a way to help you with the carb cleaner why not use a simple used 5 gal bucket that hyd oil etc comes in. Set the carb cleaner bucket inside the bigger one and snap the lid on. Or do one part of the carb at a time or buy a bigger bucket of the stuff. And yes it will evaporate and in this heat it does so fast
[Reply]  [No Email]
Farmallb
07-23-2012 06:31:04
67.142.178.21
 Re: Carb on A in reply to old, 07-22-2012 10:52:21
U right old. I called OR in my next podunk town. They had ONE. $22. Luckily they fit ford 8N and such, as that would be the only reaon they would be here in Okie country. Thanks.
[Reply]  [No Email]
old
07-23-2012 09:59:29
209.86.226.40
 Re: Carb on A in reply to Farmallb, 07-23-2012 06:31:04
In my town the common tractor parts needed to keep one running O'Reilly's will have or be able to get in 24 hours. I have a business account with them here and that saves me $$ in the long run and does not cost me any thing
[Reply]  [No Email]
Farmallb
07-23-2012 06:30:49
67.142.178.21
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
