| John Deere Tractors Discussion Forum |
Topic: G Carb troubles??
[Return to Forum]
| Author |
[Modern View]
| tomdeere
07-21-2012 18:00:31
174.54.161.52
I need some help here and I will try to be breif. I just picked up an unstyled G. When we test ran it, it sounded solid, threw out a little gray smoke and had a "miss" to it running in low gear. I brought it home and rebuilt the carb. Got some new parts and the normal gaskets, re-assembled and started the tractor. It now throws black smoke but seems to hit, "putt" fine. I re-checked the float level and the 5/8 to 3/4 top of bowl to fuel height and its good. Got the needles backed out the reccomended number of starting turns. I can't seem to think what may be different? How can I tell if a valve is stuck???? I really believe it is something simple I am missing. Any suggestions? Thanks a bunch |
| 34gpa
07-22-2012 10:30:40
173.190.183.89
Re: G Carb troubles?? in reply to tomdeere, 07-21-2012 18:00:31
| On the float level,with the bowl off,and turned up side down,The float should be 3/8 to 1/2 in. from the top of the bowl as you hold it up side down. After it is set,I reassemble and put a drain and hose in bottom hole of bowl,let it fill with fuel,and it should hold the fuel level at 3/4 in. down from top for at least 24 hours. Look at Roberts carb site to get an idea of how that test works |
| Mark-Ia
07-22-2012 07:24:47
67.55.246.70
| You may need to adjust your needles for proper operations. Most suggested settings will get you started, but you will need to fine tune your carb for your tractor. |
| FactoryFarmer
07-21-2012 20:01:40
184.20.101.206
| If it has a stuck valve then it will be nearly impossible to start and backfire through the carb. It will also have a very, very noticeable miss like it is only running on one cylinder.
New parts and gaskets do not get a carb even close to where it should be. Unless you take out all the little plugs and hone all the "stuff" out of all the passages it will never work worth a darn.
I went through the same thing on my 37 G, |
| tomdeere
07-22-2012 03:35:34
174.54.161.52
Re: G Carb troubles?? in reply to FactoryFarmer, 07-21-2012 20:01:40
| Thanks Factory Farmer. I did clean out the all the ports with little drill bits and pipe cleaners. Dipped the bowl and carb body in solvent. I think I am going to run water through the intake canister like a previous thread suggested since this tractor came from the mid west and it's now here in the east. I guess the dreadded mud daubers never make it this far. Then I will see what I have. Thanks a bunch. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
