Yesterday's Tractor Co. Fast, Friendly Parts Service
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: JD A fanshaft removal part 2
[Return to Forum]
ssgshelton
07-20-2012 18:20:14
50.55.39.234
Ok I went ahead and took off the sheet metal and the radiator so I
could clean it up and sand a few more areas and I still can't get the
fan shaft out. I have it all broke down and everything taken off
except the governor. I have both the IT manual and the parts book
and can't figure out what screws I need to remove to get it to slide
out. when I try to force it a little it acts like it is being held on my
some sort of spring action. Anyway which bolts do I take off to get
the governor off if that is the next course of action I need to take?
Thanks
[Reply]   [No Email]
greenday
07-21-2012 05:49:00
216.145.156.69
Re: JD A fanshaft removal part 2 in reply to ssgshelton, 07-20-2012 18:20:14
Sounds like the fan shaft bevel gear is not wanting to come through the govener case because there is probably some rust built up there. Just keep working it around and it will come out. I had one on a 49 A do the same thing. Dave
  [Reply]  [No Email]
Pete76NY
07-20-2012 23:26:00
66.194.51.226
Did you lift it in the front? It sits down over that cross member with a little tab that holds it there.
  [Reply]  [No Email]
ssgshelton
07-21-2012 07:12:56
50.55.45.54
Re: JD A fanshaft removal part 2 in reply to Pete76NY, 07-20-2012 23:26:00
Thanks for the replys. It is a 1949 JD A. I did remove the two bolts on front of the fanshaft to be able to lift it up. You are probably right about the rust. The reason I took off the radiator and water piping is that I probably have about 3 lbs of rust inside it as well.
I will keep working at it.
Thanks
  [Reply]  [No Email]
Pete76NY
07-20-2012 23:25:36
66.194.51.226
  [Reply]  [No Email]
Mark-Ia
07-20-2012 21:08:36
67.55.246.70
Grab ahold of the fanshaft and wiggle it or shake it, it should come loose from the gov. with the nuts and bolts removed.
  [Reply]  [No Email]
Old weldor
07-20-2012 20:05:17
67.142.183.23
Never removed one from an A but I removed one from my 51 G, I did not have to remove the governor.
  [Reply]  [No Email]
rusty wheel
07-20-2012 19:13:55
75.180.23.218
To remove the governor, you need to taker all the bolts out around the base. The governor is on dowel pins and needs to come straight up. The fan shaft and governor should both come off together. I'd check the timing marks too before you take it off.
  [Reply]  [No Email]
Brown Green
07-20-2012 19:10:05
50.33.194.36
Also, be careful of the little square oil pump coupler when you remove (or move) the governor.
  [Reply]  [No Email]
1949ABG
07-20-2012 18:36:39
208.126.169.31
Assuming the bolts are out of the bracket that holds the end of the shaft nearest the radiator, that little cover on the front side of the governor should come off. They get pretty stuck after all those years, but a little screwdriver should pop that right off.
  [Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
